[mapserver-dev] Undocumented changes in PHP MapScript
Mike Leahy mgleahy at alumni.uwaterloo.ca
Mon Apr 25 14:02:00 EDT 2011
Hi Alan,
That's the main problem I had when I ran into this - I don't get useful error
[Mon Apr 25 13:56:37 2011] [warn] [client 127.0.0.1] (104)Connection reset by
peer: mod_fcgid: error reading data from FastCGI server, referer:
https://localhost/myapp/
[Mon Apr 25 13:56:37 2011] [error] [client 127.0.0.1] Premature end of script
headers: index.php, referer: https://localhost/myapp/
[Mon Apr 25 13:56:37 2011] [error] mod_fcgid: process /usr/lib/cgi-
bin/php5(13148) exit(communication error), get unexpected signal 11
Usually, PHP will give me errors with line numbers for me to inspect, but I'm
guessing this is a segfault.  As you can see, I'm running PHP as CGI - could
that be an issue?  Is there something you'd like me to try to debug this?
Mike
On April 25, 2011 13:34:25 Alan Boudreault wrote:
> Hi,
> The methods setXY and setXYZ are still present. What do you mean? What
> error message do you get when you try to use it? Not sure what you means
> about the error message of setXY method... could you point me the error
> message you got?
> Alan
> On April 24, 2011 12:06:02 am Mike Leahy wrote:
> > Hello List,
> > I have just given the 6.0 beta 7 a try, and overall the migration guide
> > made most changes that affected my application very easy to deal with,
> > and from my tests MapServer and PHP MapScript are working as expected.
> > I'm looking forward to the final release.
> > I'm just wondering if there are any additional changes to PHP MapScript
> > library that are known, but not yet documented in the migration guide.  I
> > seem to have encountered at least one change that is not covered, which
> > tripped me
> > up briefly.  As the migration guide notes:
> > > Object properties can be set like all other php object. ie.
> > > myObj->myProperty = 10;
> > > NOTE: The set/setProperty methods are still available.
> > However, it seems that the pointObj->setXY() method is no longer present.
> > This was easily substituted by directly setting the x/y properties (e.g.,
> > $oPoint->x = $x). I recognize this particular issue is fairly trivial,
> > but since this change isn't covered in the guide.  I'm wondering if
> > there might be other differences.  There's no mention of any methods
> > other than 'free' being removed from the pointObj class.  In my case,
> > the PHP code did not fail gracefully when it setXY method, and I had to
> > hunt for a bit to find where in the code that the error was happening.
> > In other cases, using removed methods produced useful error
> > messages...so maybe something else has gone wrong specifically with the
> > setXY method.
> > Best regards,
> > Mike
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110425/8b1c16d8/attachment.html
