[mapserver-dev] 6.0 release scheduling
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri Jan 14 06:00:40 EST 2011
--------Yewondwossen Assefa <yassefa at dmsolutions.ca> wrote--------
Subject: Re: [mapserver-dev] 6.0 release scheduling
Date: 14.01.2011 05:30
>Hi Peter,
Hi Yewondwossen
>> I'm right now in front of the INSPIRE View Services docs and would add
>another item to that list: metadata. There is a large part of the specs
>dedicated to metadata, which is covered by a INSPIRE specific namespce
>(http://inspire.europa.eu/networkservice/view/1.0). Some of that metadata
>must be included in the capabilities document in order to conform to the
>INSPIRE guidelines.
>> I can not say anything how this could be handled by MapServer.
>are you refering to elements that are part of the ExtendedCapabilities
>element such as ResourceType  SpatialDataServiceType, ... ?  There seems
>to be a series of manadatory and optional elements that need to be part
>of the ExtendedCapabilities  element. Outside the extended capabilities,
>there are also few other metadata such as abstract, fees,  that are
>mandatory  (same elements that we find in regular wms)
>I think there will be a need to define in the map file an option to
>indicate that the capabilities need to be extended and extension should
>be done according to the inspire specs.  We can then have specific
>functions that can be added to read inspire type metadata to populate
>the  ExtendedCapabilities  part of the document.
>  Basically from what I can see, here are the things I see need to be
>part of the capabilities document:
>   - add a link to the inspire schema as part of the overall schema list
>   - generate an ExtendedCapabilities
>   - include all elements by reading inspire type metadata
>   - all other metadata outside that extended capabilities should
>already be part of the regular wms output
>What other elements need to be there to make it a valid getcapabilities
>response?
I would say that this should cover all INSPIRE requirements on metadata. Unfortunately I have to leave right now, but will double check the list until Monday.
>Are there other docs related to the spec beside
>http://inspire.jrc.ec.europa.eu/documents/Network_Services/Technical_Guidance_View_Services_v2.12.pdf
Theoretically WMF, described in http://inspire.jrc.ec.europa.eu/documents/Network_Services/INSPIRE%20Draft%20Technical%20Guidance%20Download%20(Version%202.0).pdf is related, too. But I could not notice any substantial difference to what is already covered in the View Services spec.
>regards,
>Assefa Yewondwossen
>Software Analyst
>Email: yassefa at dmsolutions.ca
>http://www.dmsolutions.ca/
>Phone: (613) 565-5056 (ext 14)
>Fax:   (613) 565-0925
Regards,
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
