[mapserver-dev] Documentation Question
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jul 22 07:51:23 EDT 2011
Hi Steve,
My position is that the doc contents should contain references to the
MapServer version that the feature applies to.  So yes we should
maintain backwards compatibility.  For example, /mapfile/expressions.txt
could be separated into "MapServer 6.0 Expressions" and "MapServer 5
Expressions" sections.  I would argue that this is much easier to
maintain, and makes more sense to a user.  It does ask doc contributors
and developers to specifically mention the MapServer version when they
are documenting though.  I'll give an example of what I mean:
Let's say I am a mapscript dev and I add a function to a mapscript.
Then I'd go to its doc (meaning: in trunk and also in
branch-whatever-is-live-on-web, because a user wants to know what is
available) and add:
GetXXX
   Added in MapServer version 6.2, this function gets the...
I hope this helps clarify my position.
-jeff
On 11-07-21 1:42 PM, Steve Lime wrote:
> Question for folks. What's our position regarding multi-version support
> within the documentation? For example, there were a number of syntax
> changes related to logical expressions in 6.0. We could update the
> documentation to reflect 6.0 "as is" with no references to how things
> worked in older versions. We could also try to maintain some backwards
> compatibility so that the documentation could support all versions.
> Doing so requires lots of extra explanation though and makes it harder
> to maintain. If documentation is version specific then that would argue
> for historical documentation to be made available...
