[mapserver-dev] Can msIO_stripStdoutBufferContentHeaders() return headers and be available through MapScript?
Jean-François Gigand jean-francois at gigand.fr
Tue Jun 14 12:09:51 EDT 2011
Hi again,
Since I'm on the php/msIO topic, I remember a bug (in 5.6, still in
6.0) in the ms_ioGetStdoutBufferString() PHP/MapScript function.
The function does not work with binary data, since RETURN_STRING()
assumes, as you know, a \0 byte for the end.
I have replaced it with RETURN_STRINGL() which takes a length argument
instead of relying on strlen(). It works with my PNG test.
Attached is the (tiny) patch.
Best regards,
JF Gigand
2011/6/14 Jean-François Gigand <jean-francois at gigand.fr>:
> Hi,
> I did not notice that msIO_stripStdoutBufferContentHeaders() was
> available in MapScript. The page you pointed, Stephan, is SWIG's. The
> PHP bindings in mapscript/php/php_mapscript.c are statically written
> (not based on SWIG) and do not contain the function. The following
> check confirms it at runtime:
> $ echo '<?php print ms_GetVersion()."\n";
> print_r(get_extension_funcs("mapscript"));' | php
> MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Array
>    [0] => ms_GetVersion
>    [1] => ms_GetVersionInt
>    [2] => ms_newLineObj
>    [3] => ms_newRectObj
>    [4] => ms_newShapeObj
>    [5] => ms_shapeObjFromWkt
>    [6] => ms_GetErrorObj
>    [7] => ms_ResetErrorList
>    [8] => ms_newOWSRequestObj
>    [9] => ms_newShapeFileObj
>    [10] => ms_newMapObj
>    [11] => ms_newMapObjFromString
>    [12] => ms_newLayerObj
>    [13] => ms_newPointObj
>    [14] => ms_newProjectionObj
>    [15] => ms_newStyleObj
>    [16] => ms_newSymbolObj
>    [17] => ms_newClassObj
>    [18] => ms_newGridObj
>    [19] => ms_getCwd
>    [20] => ms_getPid
>    [21] => ms_getScale
>    [22] => ms_tokenizeMap
>    [23] => ms_ioInstallStdoutToBuffer
>    [24] => ms_ioInstallStdinFromBuffer
>    [25] => ms_ioGetStdoutBufferString
>    [26] => ms_ioResetHandlers
>    [27] => ms_ioStripStdoutBufferContentType
>    [28] => ms_ioGetStdoutBufferBytes
> However, my need was to *fetch* the Content-* headers.
> In the mean time, since msIO_stripStdoutBufferContentHeaders() is in
> SWIG but not in PHP, I guess it is just missing.
> So I added it, attached is a patch, made against trunk rev 11817.
> I named the function "ms_ioStripStdoutBufferContentHeaders", following
> the naming convention of the other PHP MS bindings.
> Best regards,
> JF Gigand
> 2011/6/13 Daniel Morissette <dmorissette at mapgears.com>:
>> Maybe we couold add a new ms_ioExtractStdoutBufferHeaders() that would
>> extract and return all headers in an array?
>> On 11-06-13 11:59 AM, Stephan Meißl wrote:
>>> Jean-François,
>>> in 6.0 the exact function you propose was added (see [1]). It doesn't
>>> return the headers though. I haven't tested the function in PHP
>>> MapScript but it works with Python.
>>> cu
>>> Stephan
>>> [1] http://mapserver.org/mapscript/mapscript.html#mapscript-functions
>>> On Mon, 2011-06-13 at 15:27 +0200, Jean-François Gigand wrote:
>>>> Hi,
>>>> I use PHP MapScript and handle WxS requests through the "MapScript
>>>> Wrappers for WxS Services", which work fine.
>>>> Since 6.0 I also use OGR output (ZIP of CSV/Shapefiles), which also
>>>> works fine (much thanks, 6.0 kicks ass!).
>>>> Through {,Fast}Cgi, everything is fine.
>>>> But, through (PHP) MapScript, when the WxS request outputs a
>>>> "Content-Disposition" header, the ms_ioStripStdoutBufferContentType()
>>>> function is of no use, as the Content-Type header is not the first
>>>> one, and no MapScript method would extract the "Content-Disposition"
>>>> header anyway.
>>>> To my guess, the perfect solution would be a
>>>> msIO_stripStdoutBufferContentHeaders() function which:
>>>> - would return the headers, not just strip them off, for example
>>>> returning a<char **>
>>>> - would be available through MapScript
>>>> If you confirm the need for this solution, I can develop it and send you
>>>> a patch
>>>> (just advise me about the function name and prototype (<char***>  param
>>>> or<char**>  return?).
>>>> So far, I have done this through PHP, see the function below:
>>>>    * Strip off Content-* headers from buffer and set them on response
>>>> object
>>>>    * @param $buffer  string     Ref to buffer string, which may
>>>> include Content-* headers
>>>>    * @param $reponse Response   Framework-dependant response object to
>>>> add the headers to
>>>>   function extractContentHeaders(&$buffer, Response $response)
>>>>     $length = -1;
>>>>     $regex = "/^(Content-[a-zA-Z-]+): ([a-zA-Z0-9.\/=?!_; -]+)\n/";
>>>>     while (strlen($buffer) != $length) {
>>>>       $length = strlen($buffer);
>>>>       $cb = function($m) use ($response) {
>>>>         $response->headers->set($m[1], $m[2]);
>>>>         return '';
>>>>       $buffer = preg_replace_callback($regex,$cb, $buffer);
>>>> Best regards,
>>>> JF Gigand
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> http://www.mapgears.com/
>> Provider of Professional MapServer Support since 2000
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110614/b685c9d0/mapserver_fix_php_ms_ioGetStdoutBufferString.bin
