[mapserver-dev] Re: msautotest
Jim Klassen klassen.js at gmail.com
Fri Mar 18 11:11:54 EDT 2011
I see two issues so far...
1) The file specified in TEMPLATE needs to exist and have a valid magic string (even though it should be using the OUTPUTFORMAT template and not the Header/Template/Footer style.)
2) The Content-type header sent for msautotest/misc/result/rfc36_geojson.js is incorrect (geojson not application/json; subtype=geojson)
On Mar 18, 2011, at 10:56 AM, Lime, Steve D (DNR) wrote:
> You have to have a TEMPLATE for something to be queryable. Something is definitely wrong (most tests in msautotest/query also fail) and probably related to the default output format changes. Can someone  summarize those?
> Steve
> ________________________________________
> From: Jim Klassen [klassen.js at gmail.com]
> Sent: Friday, March 18, 2011 9:53 AM
> To: MapServer Dev Mailing List
> Cc: Lime, Steve D (DNR)
> Subject: msautotest
> We're going through msautotest at the sprint and running into a problem with templates...
> In msautotest/misc/rfc36.map it looks like it is needs TEMPLATE 'dummy' but this doesn't appear to be allowed anymore?
> Jim K
