[mapserver-dev] svn trunk error...
Jim Klassen klassen.js at gmail.com
Fri Mar 18 12:15:21 EDT 2011
Most likely because the case of the filename changed in SVN and you are on a case insensitive filesystem. (So the two names are the same in the working copy and not the same in the repository).
On Mar 18, 2011, at 12:07 PM, Lime, Steve D (DNR) wrote:
> Trying to 'svn update' and I'm getting:
>  svn: Failed to add file 'migration_guide.txt': object of the same name already exists
> Any idea why?
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
