[mapserver-dev] Fwd: RE: [FriBidi] Incorrect Arabic text rendering in maperver
Stephen Woodbridge woodbri at swoodbridge.com
Tue Mar 22 10:17:57 EDT 2011
http://trac.osgeo.org/mapserver/ticket/3763
On 3/22/2011 10:02 AM, Lime, Steve D (DNR) wrote:
> Can you create a ticket so this gets in 6.0? -Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
> Sent: Monday, March 21, 2011 8:27 PM
> To: mapserver-dev
> Subject: [mapserver-dev] Fwd: RE: [FriBidi] Incorrect Arabic text rendering in maperver
> Hmmm, I just realized this never make it to the dev list.
> -Steve W
> -------- Original Message --------
> Subject: RE: [FriBidi] Incorrect Arabic text rendering in maperver
> Date: Sun, 13 Mar 2011 03:40:52 -0400
> From: Ian Walberg<ian.walberg at airborne.aero>
> To: Stephen Woodbridge<woodbri at swoodbridge.com>
> CC: Behdad Esfahbod<behdad.esfahbod at gmail.com>,<mapserver-devs at lists.osgeo.org>
> Stephen,
> Attached is the modified mapserver mapstring.c file which includes changes based on your code snippet.
> We have tested this today in our configuration and this solves the issue we had.
> I have not previous submitted a change so I am not sure what the process is.
> Regards
> Ian
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Saturday, March 12, 2011 7:35 PM
> To: Ian Walberg
> Subject: Re: [FriBidi] Incorrect Arabic text rendering in maperver
> Ian,
> I'm have not followed all of this thread, but from what I have gathered,
>    the mapserver code needs to walk over the string and remove these characters which seems reasonable.
> So if you are up to making a patch to mapserver and attaching that to a
>    the bug you opened, we can see if we can get it reviewed and added to
>    6.0 which just went to beta.
> FRIBIDI_CHAR_FILL is evidently a three byte sequence if I recall from an
>    earlier post on this thread.
>    >  Also does FRIBIDI_CHAR_FILL get converted to a single utf8 character?
>    >  What is its value?
> \xef\xbb\xbf.
> This is untested, but I think something like this should work to remove the FRIBIDI_CHAR_FILL character sequences. You will need to adapt it to the mapserver code.
> /* scan str and compress out FRIBIDI_CHAR_FILL UTF8 characters */ if (utf8) {
>      len = strlen(str);
>      for (i=0, j=0; i<len; i++, j++) {
>        if (str[i] == '\xef'&&  str[i+1] == '\xbb'&&  str[i+2] == '\xbf')
>          i += 3;
>        if (i != j) str[j] = str[i];
>      str[j] = '\0';
> -Steve W
> On 3/12/2011 7:04 PM, Behdad Esfahbod wrote:
>> On 03/09/11 14:08, Ian Walberg wrote:
>>> Behdad,
>> Hello,
>>> We are back looking at this again and have tried a few combinations and none seem to work.
>>> Here is the test change we made to fribidi-arabic.c
>>> for (i = 0; i<   len - 1; i++) {
>>>       register FriBidiChar c;
>>>       if (FRIBIDI_LEVEL_IS_RTL(embedding_levels[i])&&
>>>           embedding_levels[i] == embedding_levels[i+1]&&
>>>           (c = PAIR_MATCH(table, size, str[i], str[i+1])))
>>>           /* str[i] = FRIBIDI_CHAR_FILL; */ // Do we need to remove
>>> this next line as well?
>>>           FRIBIDI_SET_BITS(ar_props[i], FRIBIDI_MASK_LIGATURED);
>>>           /* str[i+1] = c; */
>>>           str[i] = c;
>> I suggest instead of changing the FriBidi code you simply walk over
>> the output string and remove the filler character.
>> behdad
>>> The assumption is that we would make the 'real' change to mapserver and not here.
>>> Thanks
>>> Ian
