[mapserver-dev] msautotest crashing on Windows
Stephan Meißl stephan at meissl.name
Wed Mar 23 05:47:55 EDT 2011
Sorry for accidentally resolving this issue ;). We had problems calling
msCleanup() from Python MapScript. Let me know if I can help somewhere
else too :).
cu
Stephan
On Tue, 2011-03-22 at 16:44 +0100, Tamas Szekeres wrote:
> Yes it seems to fix the problem.
> Best regards,
> Tamas
> 2011/3/21 Daniel Morissette <dmorissette at mapgears.com>
>         Could Stephan's fix of a double free earlier today also fix
>         this?
>         http://trac.osgeo.org/mapserver/changeset/11294
>         On 11-03-21 11:30 AM, Alan Boudreault wrote:
>                 Emm, these urls work fine on linux. Could anyone pass
>                 a valgrind or a gdb on
>                 Windows to see where's the problem?
>                 Thanks,
>                 Alan
>                 On March 20, 2011 06:20:20 pm Tamas Szekeres wrote:
>                         Alan,
>                         Here are some examples:
>                         mapserv
>                         QUERY_STRING="map=sos.map&service=SOS&version=1.0.0"
>                         (msautotest\wxs\)
>                         mapserv
>                         QUERY_STRING="map=rfc36.map&mode=nquery&layer=popplace"
>                         (msautotest\misc\)
>                         mapserv
>                         QUERY_STRING="map=rfc36_ogr.map&mode=nquery&layer=popplace"
>                         (msautotest\misc\)
>                         mapserv
>                         QUERY_STRING="map=sos.map&SERVICE=SOS&VERSION=1.0.0&REQUEST=GetCapabilities
>                         &updatesequence=f" (msautotest\wxs\)
>                         mapserv
>                         &acceptversions=0.0.31,0.1.4,1.0.0" (msautotest\wxs\)
>                         mapserv
>                         QUERY_STRING="map=tomk_workshop.map&service=WMS&version=1.1.1&request=Descr
>                         ibeLayer&layers=rivers" (msautotest\wxs\)
>                         mapserv
>                         QUERY_STRING="map=wfs_filter.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeatu
>                         re&TYPENAME=popplace&FILTER=<Filter><PropertyIsGreaterThanOrEqualTo><Proper
>                         tyName>POP_RANGE</PropertyName><Literal>4</Literal></PropertyIsGreaterThanO
>                         rEqualTo></Filter>" (msautotest\wxs\)
>                         Best regards,
>                         Tamas
>                         2011/3/20 Alan
>                         Boudreault<aboudreault at mapgears.com>
>                                 Tamas,
>                                 Could you point me the tests that
>                                 fail... I will try them on Linux
>                                 first.
>                                 Alan
>                                 On March 19, 2011 01:53:40 pm Tamas
>                                 Szekeres wrote:
>                                         Not sure about this, the
>                                         current version (r11282 in
>                                         trunk) is also
>                                         crashing.
>                                         Best regards,
>                                         Tamas
>                                         2011/3/19 Even
>                                         Rouault<even.rouault at mines-paris.org>
>                                                 Le samedi 19 mars 2011
>                                                 18:19:08, Tamas
>                                                 Szekeres a écrit :
>                                                         Hi All,
>                                                         I'm
>                                                         experiencing
>                                                         permanent
>                                                         crashes in
>                                                         msautotest on
>                                                         Windows which
>                                                 prevents
>                                                         from the daily
>                                                         builds on
>                                                         http://vbkto.dyndns.org/sdk/ to complete
>                                                         successfully.
>                                                         While I'm not
>                                                         sure about the
>                                                         exact location
>                                                         of the problem
>                                                         I
>                                                         suspect
>                                 it
>                                                 may
>                                                         be due to a
>                                                         recent change
>                                                         in the lexer.
>                                                         According to
>                                                         my
>                                                         examinations
>                                                         the problem
>                                                         has been
>                                                         introduced
>                                                         between
>                                                 r11192
>                                                         and r11196.
>                                                         Could someone
>                                                         look into the
>                                                         problem who
>                                                         has better
>                                                         knowledge
>                                                         about
>                                 the
>                                                         changes above?
>                                                 Tamas, I believe this
>                                                 has been fixed by
>                                                 http://trac.osgeo.org/mapserver/changeset/11224
>                                                         Best regards,
>                                                         Tamas
>         Daniel Morissette
>         http://www.mapgears.com/
>         Provider of Professional MapServer Support since 2000
>         _______________________________________________
>         mapserver-dev mailing list
>         mapserver-dev at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/mapserver-dev
