[mapserver-dev] RE: 6.0 release plan - RFC45 - Consistent units in CLASS-> STYLE
thomas bonfort thomas.bonfort at gmail.com
Mon Mar 28 08:54:05 EDT 2011
With +1 from sdlime, tbonfort, woodbri, danmo, perry, assefa and
tamas, we can now welcome Havard as a doc committer.
I've added your osgeo userid to the mapserver_docs group, so you
should now be able to commit to the docs.
cheers,
thomas
On Thu, Mar 24, 2011 at 20:50, Tamas Szekeres <szekerest at gmail.com> wrote:
> +1
> Tamas
> 2011/3/24 Lime, Steve D (DNR) <steve.lime at state.mn.us>
>> I suppose we should talk on mapserver-dev. ;-) I'm happy to nominate you
>> for documentation
>> commit access. We like to try to match commits with tickets if
>> non-trivial. There is a documentation
>> component in trac that Jeff owns that can be used for that.
>> One thing to note is that Jeff and Mike Smith started or at least pondered
>> staring an "examples"
>> effort in Montreal. I could see some of your symbolization examples being
>> very useful in that context
>> too.
>> I'll start with a +1 on granting Havard Tveite commit access for
>> documentation.
>> Steve
>> -----Original Message-----
>> From: Havard Tveite [mailto:havard.tveite at umb.no]
>> Sent: Thursday, March 24, 2011 11:25 AM
>> To: Lime, Steve D (DNR)
>> Cc: thomas.bonfort at gmail.com
>> Subject: Re: 6.0 release plan - RFC45 - Consistent units in CLASS-> STYLE
>> Dear Steve,
>> I would be happy to contribute on the documentation
>> related to rendering for version 6.  I will, of course,
>> have to consult you and Thomas in order to get
>> clarifications on what intended behaviour is in some
>> cases...
>> How do we proceed?  My osgeo user name is havatv.
>> I have no experience with committing (I have only
>> used SVN to check out).  Is there any documentation
>> that can help me avoid making big mistakes when
>> committing?
>> I have found a book, that I hope can help:
>> http://svnbook.red-bean.com/en/1.4/svn-book.pdf
>> Is it enough to issue the svn commit command with a
>> descriptive message using --message?
>> I have had a look at the documentation development
>> guide (http://mapserver.org/development/documentation.html),
>> which seems reasonably straight forward.
>> I have also read RFC 7.1, and have no problems with that.
>> Håvard
>> On 3/24/2011 3:42 PM, Lime, Steve D (DNR) wrote:
>> > We'd be happy to have more documentation committers...
>> > From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>> > Sent: Thursday, March 24, 2011 4:46 AM
>> > To: Havard Tveite
>> > Cc: Lime, Steve D (DNR)
>> >  STYLE
>> > Thanks Havard,
>> > For the documentation changes, it would probably be easier if you
>> > could commit directly into the mapserver documentation site. I seem to
>> > recall that for docs commit access, it is sufficient to post a short
>> > message to the -dev list stating which areas you want to work on, and
>> > your osgeo userid.
>> > ps: good news for rfc45, I've just been on the phone with a customer
>> > here in france who will probably be funding the anchorpoint stuff :)
>> > On Thu, Mar 24, 2011 at 10:22, Havard Tveite<havard.tveite at umb.no>
>> >  wrote:
>> >> An updated examples.sym (just the explaining text has changed).
>> >> Håvard
>> >> On 3/24/2011 10:17 AM, Håvard Tveite wrote:
>> >>> Very nice!
>> >>> How can I help updating the documentation?
>> >>> Another thing:
>> >>> I looked at the 6beta distribution and found that there
>> >>> was a symbol directory.
>> >>> I have updated the files in that directory to use the
>> >>> Mapserver 6 mechanisms.  You will find the new files
>> >>> attached.  I have also included two PNG files that show
>> >>> the images produced by the previous map and symbol files
>> >>> using Mapserver 5.2 (example-org.png) and my updated
>> >>> files using 6beta3 (example.png).
>> >>> I have only updated the existing examples, but could
>> >>> add other (more advanced) examples if you like.
>> >>> Håvard
>> >>> On 3/23/2011 4:07 PM, thomas bonfort wrote:
>> >>>> Havard,
>> >>>> fixed in trunk, please confirm ;)
>> >>>> thanks for testing!
>> >>>> thomas
>> >>>> On Tue, Mar 22, 2011 at 15:27, Havard Tveite<havard.tveite at umb.no>
>> >>>> wrote:
>> >>>>> Dear Thomas and Steve,
>> >>>>> I have now tested quite a bit on 6beta2.
>> >>>>> Many improvements!
>> >>>>> I have one big concern that I think needs to be addressed
>> >>>>> for 6.0:
>> >>>>> Units in LAYER->     CLASS->     STYLE
>> >>>>> The units used for the different elements of the STYLE now
>> >>>>> vary, and I think that will be very confusing to the users.
>> >>>>> * WIDTH and SIZE specifies the width/height of the line/symbol
>> >>>>>    as the number of pixels/map units at the scale
>> >>>>>    1:SYMBOLSCALEDENOM.  I like this!
>> >>>>> * GAP uses the same units (that is the gap in pixels/map units
>> >>>>>    at the scale 1:SYMBOLSCALEDENOM).  I like this!
>> >>>>> * PATTERN uses the WIDTH of the line as the unit, so to get
>> >>>>>    the gap as the number of pixels/map units at the scale
>> >>>>>    1:SYMBOLSCALEDENOM, you have to multiply the GAP value by
>> >>>>>    the value of WIDTH.  I don't like this!
>> >>>>> * OFFSET seems to use the same approach as PATTERN when
>> >>>>>    "displacing" lines (units relative to line WIDTH).
>> >>>>>    For point symbols, it seems to use the same approach as GAP
>> >>>>>    (pixels/map units at the scale 1:SYMBOLSCALEDENOM).
>> >>>>> My opinion is that the unit used for all the length/width/size
>> >>>>> measure elements (GAP, OFFSET, PATTERN, SIZE, WIDTH) of
>> >>>>> CLASS->     STYLE should be the number of pixels/map units at the
>> >>>>> scale 1:SYMBOLSCALEDENOM (as is currently the case for WIDTH,
>> >>>>> SIZE and GAP).  This would mean that the units used for
>> >>>>> PATTERN and OFFSET (for lines) would have to be changed.
>> >>>>> Håvard
>> >>>>> On 11/18/2010 4:13 PM, thomas bonfort wrote:
>> >>>>>> Havard,
>> >>>>>> rfc45 isn't dead, but the priority now is getting 6.0 out of the
>> >>>>>> door,
>> >>>>>> so I wouldn't expect those features by then.
>> >>>>>> Once 6.0 is out, getting those features in is a matter of time
>> >>>>>> and/or
>> >>>>>> will and/or funding.
>> >>>>>> cheers,
>> >>>>>> thomas
>> >>>>>> On Tue, Nov 9, 2010 at 16:23, Havard Tveite<havard.tveite at umb.no>
>> >>>>>> wrote:
>> >>>>>>> Dear Steve and Thomas,
>> >>>>>>> I have been extremely busy this summer and autumn, so I
>> >>>>>>> have not been able to follow Mapserver developments very
>> >>>>>>> closely.  But when I heard about the release plan for 6.0,
>> >>>>>>> I thought about RFC45.  There has been some interest
>> >>>>>>> during the last years for some of the suggestions there,
>> >>>>>>> and I still think that it includes some very good ideas
>> >>>>>>> for quality improvements of Mapserver symbol rendering.
>> >>>>>>> I have kept track of the progress on Cairo, so I don't know
>> >>>>>>> if anything of this has been addressed there.
>> >>>>>>> Here are some examples:
>> >>>>>>> Stable origin for tile generation + polygon fill symbols:
>> >>>>>>>     This would require that for instance the coordinate system
>> >>>>>>>     origo be used instead of a local origo when placing tiles
>> >>>>>>> Angle options - there has been some demand for compass (the
>> >>>>>>>     current vector? default).
>> >>>>>>> Possibility to specify symbol origin for precise placement
>> >>>>>>>     of symbols.
>> >>>>>>> And more.
>> >>>>>>> Someone more familiar with the Mapserver code should perhaps
>> >>>>>>> go through RFC45 again and check what can be achieved for 6.0.
>> >>>>>>> I may have the time in a few weeks to help with specifications.
>> >>>>>>> Håvard Tveite
>> >>>>>>> On 11/9/2010 8:59 AM, thomas bonfort wrote:
>> >>>>>>>> On Mon, Nov 8, 2010 at 18:07, Lime, Steve D (DNR)
>> >>>>>>>> <Steve.Lime at state.mn.us>         wrote:
>> >>>>>>>>> RFC-50: I think this is out for 6.0 unless those authors are
>> >>>>>>>>> still
>> >>>>>>>>> around.
>> >>>>>>>> yes definitely. I'd like to tackle that one some day, but haven't
>> >>>>>>>> got
>> >>>>>>>> the time in the near future
>> >>>>>>>>> RFC-52: The changes I’d like to see are relatively minor (from a
>> >>>>>>>>> coding
>> >>>>>>>>> perspective) and are a return to a single getShape() method in
>> >>>>>>>>> MapScript.
>> >>>>>>>>> It
>> >>>>>>>>> will break 5.6 scripts but is simpler in the long run. I don’t
>> >>>>>>>>> know
>> >>>>>>>>> that
>> >>>>>>>>> an
>> >>>>>>>>> RFC is necessary but I will start a ticket and we can go from
>> >>>>>>>>> there.
>> >>>>>>>>> RFC-54: I think Thomas just needs to merge?
>> >>>>>>>> I'm planning to do this before the end of the month. It might
>> >>>>>>>> slip a
>> >>>>>>>> bit from the planned 15th november
>> >>>>>>>>> RFC-58 – RFC-63: Are all basically complete, perhaps need docs
>> >>>>>>>>> though.
>> >>>>>>>> RFC58 (kml) still needs a bit of love before being ready
>> >>>>>>>>> RFC-64: Needs feedback. This may push us back a week or two
>> >>>>>>>>> depending
>> >>>>>>>>> on
>> >>>>>>>>> feedback. I think 6.0 is the right time to implement though
>> >>>>>>>>> given
>> >>>>>>>>> the
>> >>>>>>>>> types
>> >>>>>>>>> of proposed changes. They are not candidates for minor releases.
>> >>>>>>>>> Thanks for pushing on this…
>> >>>>>>>>> Steve
>> >>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org
>> >>>>>>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
>> >>>>>>>>> Tamas
>> >>>>>>>>> Szekeres
>> >>>>>>>>> Sent: Saturday, November 06, 2010 6:12 PM
>> >>>>>>>>> To: mapserver-dev at lists.osgeo.org
>> >>>>>>>>> Subject: [mapserver-dev] 6.0 release plan
>> >>>>>>>>> Hi All,
>> >>>>>>>>> In search of my memory (and my mails) the recent plan of the 6.0
>> >>>>>>>>> release
>> >>>>>>>>> has
>> >>>>>>>>> been scheduled as follows:
>> >>>>>>>>> "Plan for a feature freeze on Nov 15th, with a little over 2
>> >>>>>>>>> months
>> >>>>>>>>> for
>> >>>>>>>>> betas, aiming for final release between Jan 15th and 31st"
>> >>>>>>>>> How do we stand with the upcoming activities in the light of
>> >>>>>>>>> this?
>> >>>>>>>>> I can see the following RFCs may be affected or must be
>> >>>>>>>>> scheduled:
>> >>>>>>>>> RFC-50 (OpenGL)
>> >>>>>>>>> RFC-52 (One-pass query processing), we wanted to do some rework
>> >>>>>>>>> as
>> >>>>>>>>> far
>> >>>>>>>>> as
>> >>>>>>>>> I
>> >>>>>>>>> remember.
>> >>>>>>>>> RFC-54 (Rendering overhaul)
>> >>>>>>>>> RFC-58 (KML output)
>> >>>>>>>>> RFC-62 (Additional WFS GetFeature Output Formats)
>> >>>>>>>>> RFC-63 (OpenLayers viewer)
>> >>>>>>>>> RFC-64 (Expression parser overhaul)
>> >>>>>>>>> Do we have any other plan which will be covered with an RFC
>> >>>>>>>>> soon?
>> >>>>>>>>> How
>> >>>>>>>>> much
>> >>>>>>>>> time the pending efforts will take to be implemented?
>> >>>>>>>>> The 6.0 release plan document may also updated with some up to
>> >>>>>>>>> date
>> >>>>>>>>> information if possible.
>> >>>>>>>>> Best regards,
>> >>>>>>>>> Tamas
>> >>>>>>>>> _______________________________________________
>> >>>>>>>>> mapserver-dev mailing list
>> >>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> >>>>>>> Håvard Tveite
>> >>>>>>> Department of Mathematical Sciences and Technology, UMB
>> >>>>>>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> >>>>>>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
>> >>>>> Håvard Tveite
>> >> Håvard Tveite
>> Håvard Tveite
