[mapserver-dev] MSAUTOTEST query/querymap.map
Lime, Steve D (DNR) steve.lime at state.mn.us
Tue Mar 29 23:37:47 EDT 2011
Yep, that did it. Thanks man!
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
Sent: Tuesday, March 29, 2011 11:09 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] MSAUTOTEST query/querymap.map
On 11-03-28 11:41 PM, Lime, Steve D (DNR) wrote:
> Hi all: These tests are all failing with an error seen on the last day of the sprint:
>    msReturnPage(): Web application error. Malformed template name (void).
> The tests all use the GIF output format since GD should produce more stable images with no anti-aliasing. Anyway, the QUERYFORMAT parameter is used to set the output format to use with query results. I'm guessing the error is happening because the default GIF format is not defined. Any idea how to fix?
Steve,
Sorry, I thought we had already taken care of this.  I have just committed
r11365 which initializes the output formats before looking for the format in
msReturnTemplateQuery().  The querymap.map tests should pass now.
Best regards,
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
