[mapserver-dev] Plugin for ESRI File Geodatabase?Support
Daniel Morissette dmorissette at mapgears.com
Wed May 18 11:16:16 EDT 2011
On 11-05-18 11:01 AM, Lime, Steve D (DNR) wrote:
> Looks to be Windows specific?
Maybe you're right. There is no Linux Makefile in the OGR driver's
directory, so it is quite possible that it's been tested only on Windows
so far. I'd hope that the code would also work on Linux once the API is
available there.
In case you're interested you can browse the source of the OGR driver here:
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/filegdb
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
