R: R: [mapserver-dev] Re: Problem with projectionObj
GMail itacasoft at gmail.com
Tue Oct 4 16:49:25 EDT 2011
Thanks a lot for the suggestion about the "windowsdebug", very interesting.
It works with Cassini (the VS2010 web debugger) giving some debug lines, but
not with IIS 7.0 (another permission issue??).
Information got from windowsdebug did not resolve.
-----Messaggio originale-----
Da: mapserver-dev-bounces at lists.osgeo.org
[mailto:mapserver-dev-bounces at lists.osgeo.org] Per conto di Daniel
Morissette
Inviato: martedì 4 ottobre 2011 17:42
A: mapserver-dev at lists.osgeo.org
Oggetto: Re: R: [mapserver-dev] Re: Problem with projectionObj
On 11-10-04 11:37 AM, GMail wrote:
> Thanks for your answer.
> The first explanation is not possible, because the same code works for IIS
> 6.0, while it does not on IIS 7.0.
> The second is something I do not understand: using MapScript and ASP.NET I
> do not have a process "mapserv" that can crash ... but I understand that
if
> the IIS handler process crashes or hangs in some way, it may block the
> output buffer, and this is likely. But this does not explain why this
> happens only on IIS 7.0 and not on IIS 6.0. How can I have more log
> information?
Maybe a permission issue? Sorry, I'm no IIS expert, just guessing...
Maybe try using MS_ERRORFILE "windowsdebug" with tools such as DebugView
and see if that makes any difference?
http://mapserver.org/optimization/debugging.html#step-1-set-the-ms-errorfile
-variable
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
