[mapserver-dev] Generate mapfile from S57/ENC data
boortwijn boortwijn at stepscout.com
Fri Oct 7 03:06:32 EDT 2011
Hej,
I'm working on a site to display nautical charts based on S57 (ENC) format.
Currently working with the NOAA ENC data set.
I was wondering if you could help to automatically generate a mapfile based
on the NOAA ENC set. The idea would be to implement a script that parses all
the sub-directories with data in S57 format, and construct a mapfile.
Where could I find information on this or sample scripts?
Thanks in advance.
Grt, Bart
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-mapfile-from-S57-ENC-data-tp6868398p6868398.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
