[mapserver-dev] svn update error
Stephen Woodbridge woodbri at swoodbridge.com
Sat Oct 15 14:39:33 EDT 2011
Alan,
I do not have that file in my copy and in fact did a clean checkout of
trunk and that generated the same error.
Looking at the error message it says:
svn: URL ... refers to a file, not a directory
for the external reference so maybe the external reference is not
getting setup correctly and regardless I have not file
'docs/en/MIGRATION_GUIDE.txt'
So somebody that knows more than me about this problem needs to look
into it as I do not think it is doing whatever people think it is
supposed to be doing.
Thanks,
   -Steve W
On 10/15/2011 11:14 AM, Alan Boudreault wrote:
> Hi Stephen,
> Not sure if it's your case... but since a while..that file has been
> removed from the repo and is now an external reference. (doc needs) Try
> to just remove manually the file then 'svn up'.
> Alan
> On 11-10-14 05:02 PM, Stephen Woodbridge wrote:
>> Hi all,
>> I just did an svn update and got the following:
>> woodbri at mappy:/u/software/mapserver-svn$ svn update
>> Fetching external item into 'docs/en/MIGRATION_GUIDE.txt'
>> svn: URL
>> 'https://svn.osgeo.org/mapserver/trunk/mapserver/MIGRATION_GUIDE.txt'
>> Any thoughts?
>> Do others get this, or is this just me?
>> Thanks,
>> -Steve W
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
