[mapserver-dev] Writing text to image after map rendering
Tamas Szekeres szekerest at gmail.com
Thu Oct 27 15:36:57 EDT 2011
Fabrizio,
The most reasonable approach is to add a new annotation layer to the mapObj
with the desired transform, opacity and postlabelcache setting.
Alternatively you could load the resulting byte array to a .NET Image object
then use GDI+ to draw the text over the image.
Best regards,
Tamas
2011/10/26 GMail <itacasoft at gmail.com>
> Hello everybody,
> I'm using MapScript-C# to render PNG map images and send it to a
> Silverlight
> client.
> Is it possible to write some text (e.g.: copyright information) to the
> imageObj before to send the image stream to the client? How?
> Thanks
> Fabrizio
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111027/2164bc39/attachment.html
