[mapserver-dev] RFC84 call for vote: migrate from svn/trac to git/github
thomas bonfort thomas.bonfort at gmail.com
Mon Apr 2 13:48:22 EDT 2012
On Mon, Apr 2, 2012 at 19:16, Tamas Szekeres <szekerest at gmail.com> wrote:
> +1
> Tamas
> PS: WRT the issue tracking, couldn't we set up something like
> http://hub.qgis.org/ which is indeed integrated with an osgeo ID?
Tamas,
with regards to issue tracking, I think it is an impossible task to
find a product or solution that is the perfect fit for everyone.
Github has the advantage of going on well with git workflows and not
needing any setup, hosting or maintenance effort. If someone is
willing to setup another solution, import the existing tickets, then
host and maintain it I will not oppose it.
best regards,
thomas
> 2012/4/2 thomas bonfort <thomas.bonfort at gmail.com>
>> http://trac.osgeo.org/mapserver/browser/trunk/docs/en/development/rfc/ms-rfc-84.txt
>> I have updated the RFC with the discussion related to ticket history
>> (which can be nearly seamlessly imported), and removed the option of
>> continuing using the current trac instance.
>> The target result can be found here: https://github.com/mapserver
>> (still missing the msautotest and tinyows repos, and with a temporary
>> ms-import one)
>> Given that the discussion around this RFC has happened and that most
>> of the reluctances have been sorted out, I would like to call for a
>> vote on this. In case of success, trac and svn would need to be
>> freezed, and we could be up and running on github by the end of the
>> week.
>> I'll start with my +1
>> regards,
>> thomas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
