[mapserver-dev] RPMs from trunk
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Apr 20 14:35:53 EDT 2012
Hi Stephan,
Thank you for your efforts. I was about to start this work for openSUSE
soon :)
I agree that we should keep spec files to the repository and I would be
happy to contribute mine from openSUSE Build Service
Regards,
Angelos
On 04/20/2012 05:34 PM, Stephan Meißl wrote:
> Hi devs,
> not being an expert I've put some effort to generate RPMs for CentOS
> from current trunk. I partially succeeded to update the spec file to the
> new build procedure (see attached). Note that I did not manage to build
> PHP packages and that I had to disable this
> check: /usr/lib/rpm/check-buildroot
> Anyway, maybe this can be of some help to the MapServer RPM maintainers.
> Question to all: What do you think about adding build files (spec file
> for RPM) to the repository for reference?
> The pull request 4289 [1] includes some changes that where necessary
> along the way. Thanks for review and any comments. If there are no
> objections I'll merge it next week.
> @Thomas: I hope I'm using git and gitgut as intended?
> cu
> Stephan
> [1] https://github.com/mapserver/mapserver/pull/4289
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120420/7699ed89/attachment.html
