[mapserver-dev] Storing multiple output formats in mapfiles
thomas bonfort thomas.bonfort at gmail.com
Sat Apr 21 05:48:33 EDT 2012
Tamas,
Looking at the code, I believe this is done because the map's
outputformat has already been written (just before the loop you
copied). So this test should be maintained, however I would use the
string comparison on the outputformat's name rather than driver.
regards,
thomas
On Fri, Apr 20, 2012 at 10:21, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi Devs,
> We would like to store multiple outputformat entries for the same driver in
> the mapfiles. However when using the save option the writer does not allow
> saving formats for the same driver as what have been referenced by the
> imagetype setting. The related code now looks like this:
> for(i=0; i<map->numoutputformats; i++) {
>     if(map->outputformatlist[i]->inmapfile == MS_TRUE &&
> strcmp(map->outputformatlist[i]->driver, map->outputformat->driver) != 0)
>       writeOutputformatobject(stream, indent, map->outputformatlist[i]);
> Do we have any compelling reason to work this way or we can safely remove
> this check from writeOutputformat?
> Best regards,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
