[mapserver-dev] mapcache compile issue
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 26 03:23:09 EDT 2012
Hi Steve,
Lenny is now unsupported by debian themselves, and sqlite 3.5 is
getting rather old. I'm not surprised that mapcache won't compile
against it, and will not personally commit to making it happen,
although will apply a pull request if submitted.
regards,
thomas
On Thu, Apr 26, 2012 at 06:14, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Hi Thomas,
> Just tried to compile mapcache trunk from git and failed with the following:
> /bin/sh ../libtool --tag CC --mode=compile gcc -DUSE_PCRE -DUSE_OGR
> -DUSE_GEOS -DUSE_SQLITE -DUSE_TIFF -DUSE_BDB -DLINUX=2 -D_REENTRANT
> -D_GNU_SOURCE -pthread -O2 -Wall -DHAVE_SYMLINK -DNDEBUG -I../include
> -I/usr/include/apr-1.0 -I/usr/include/apr-1.0 -I/usr/include/postgresql
> -I/usr/include/mysql -c cache_sqlite.c
> libtool: compile: gcc -DUSE_PCRE -DUSE_OGR -DUSE_GEOS -DUSE_SQLITE
> -DUSE_TIFF -DUSE_BDB -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE -pthread -O2 -Wall
> -DHAVE_SYMLINK -DNDEBUG -I../include -I/usr/include/apr-1.0
> -I/usr/include/apr-1.0 -I/usr/include/postgresql -I/usr/include/mysql -c
> cache_sqlite.c -fPIC -DPIC -o .libs/cache_sqlite.o
> cache_sqlite.c: In function '_sqlite_reslist_get_rw_connection':
> cache_sqlite.c:111: error: 'SQLITE_OPEN_NOMUTEX' undeclared (first use in
> this function)
> cache_sqlite.c:111: error: (Each undeclared identifier is reported only once
> cache_sqlite.c:111: error: for each function it appears in.)
> cache_sqlite.c: In function '_sqlite_reslist_get_ro_connection':
> cache_sqlite.c:143: error: 'SQLITE_OPEN_NOMUTEX' undeclared (first use in
> this function)
> '_mapcache_cache_sqlite_configuration_parse_xml':
> cache_sqlite.c:386: warning: implicit declaration of function
> 'sqlite3_initialize'
> cache_sqlite.c:388: warning: implicit declaration of function
> 'sqlite3_config'
> cache_sqlite.c:388: error: 'SQLITE_CONFIG_MULTITHREAD' undeclared (first use
> in this function)
> make[1]: *** [cache_sqlite.lo] Error 1
> make[1]: Leaving directory `/u/software/mapserver-git/mapcache/lib'
> make: *** [all] Error 2
> Configured like this:
> woodbri at mappy:/u/software/mapserver-git/mapcache$ ./configure
> --enable-module
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking how to print strings... printf
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for a sed that does not truncate output... /bin/sed
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for fgrep... /bin/grep -F
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
> checking the name lister (/usr/bin/nm -B) interface... BSD nm
> checking whether ln -s works... yes
> checking the maximum length of command line arguments... 98304
> checking whether the shell understands some XSI constructs... yes
> checking whether the shell understands "+="... yes
> checking how to convert x86_64-unknown-linux-gnu file names to
> x86_64-unknown-linux-gnu format... func_convert_file_noop
> checking how to convert x86_64-unknown-linux-gnu file names to toolchain
> checking for /usr/bin/ld option to reload object files... -r
> checking for objdump... objdump
> checking how to recognize dependent libraries... pass_all
> checking for dlltool... no
> checking how to associate runtime and link libraries... printf %s\n
> checking for ar... ar
> checking for archiver @FILE support... @
> checking for strip... strip
> checking for ranlib... ranlib
> checking for gawk... no
> checking for mawk... mawk
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for sysroot... no
> checking for mt... mt
> checking if mt is a manifest tool... no
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for dlfcn.h... yes
> checking for objdir... .libs
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC -DPIC
> checking if gcc PIC flag -fPIC -DPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -c -o file.o... (cached) yes
> checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared
> libraries... yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... no
> checking for gcc... (cached) gcc
> checking whether we are using the GNU C compiler... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for gcc option to accept ISO C89... (cached) none needed
> checking for a BSD-compatible install... /usr/bin/install -c
> checking for ANSI C header files... (cached) yes
> checking for symlink... yes
> checking for apxs2... /usr/bin/apxs2
> checking for apachectl utility... /usr/sbin/apache2ctl
> checking whether to enable FASTCGI... not requested. use --with-fastcgi=dir
> to enable
> checking for apr-config in default locations... using /usr/bin/apr-config,
> use --with-apr-config=/path/to/apr-(1-)config to modify
> checking for apu-config in default locations... using /usr/bin/apu-config,
> use --with-apu-config=/path/to/apu-(1-)config to modify
> checking for apr_memcache_hash in -laprutil-1... no
> configure: WARNING: supplied apr-util does not contain memcache functions.
> memcache cache backend disabled
> checking sqlite3.h usability... yes
> checking sqlite3.h presence... yes
> checking for sqlite3.h... yes
> checking for sqlite3_open_v2 in -lsqlite3... yes
> using libsqlite3 from system libs.
> checking for pkg-config... /usr/bin/pkg-config
> checking for Pixman... searching default locations
> checking for pixman pkg-config entry... found
> checking if pixman version is >= 0.13.2... 0.10.0
> configure: WARNING: pixman support has been disabled because your version is
> too old.
> full WMS will use the internal (usually slower) image
> merging functions
> configure: checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> checking png.h usability... yes
> checking png.h presence... yes
> checking for png.h... yes
> using libpng from system libs.
> checking setjmp.h usability... yes
> checking setjmp.h presence... yes
> checking for setjmp.h... yes
> configure: checking where JPEG is installed...
> checking for jpeg_read_header in -ljpeg... yes
> checking jpeglib.h usability... yes
> checking jpeglib.h presence... yes
> checking for jpeglib.h... yes
> using libjpeg from system libs.
> configure: checking where TIFF is installed...
> checking for TIFFReadScanline in -ltiff... yes
> checking tiffio.h usability... yes
> checking tiffio.h presence... yes
> checking for tiffio.h... yes
> using libtiff from system libs.
> checking for pcre library inclusion... in system locations
> checking for pcre_compile in -lpcre... yes
> checking pcre.h usability... yes
> checking pcre.h presence... yes
> checking for pcre.h... yes
> checking for gdal-config... /usr/local/bin/gdal-config
> checking for geos-config... /usr/bin/geos-config
> checking for GEOSPreparedIntersects in -lgeos_c... yes
> checking for db.h... 4.6.21
> checking for library containing Berkeley DB 4.6.21... -ldb
> checking in /usr/local/BerkeleyDB.4.5/include for db.h... yes
> checking in /usr/local/BerkeleyDB.4.5/lib for library -ldb... 4.5.20
> configure: using Berkeley DB version 4.6.21
> checking for curl-config... /usr/bin/curl-config
> configure: creating ./config.status
> config.status: creating Makefile.inc
> config.status: creating nginx/config
> config.status: creating lib/Makefile
> config.status: creating apache/Makefile
> config.status: creating util/Makefile
> config.status: creating cgi/Makefile
> config.status: executing libtool commands
> Have SQLite versions:
> libsqlite3-0/lenny uptodate 3.5.9-6
> libsqlite3-dev/lenny uptodate 3.5.9-6
> Any ideas?
> I can open a ticket if you want it.
> Thanks,
> -Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
