[mapserver-dev] [mapscript][python] does outputformatObj has missing method?
Yves Jacolin yves.jacolin at camptocamp.com
Fri Dec 28 02:48:41 PST 2012
Thanks!
Here are the two issues:
* https://github.com/mapserver/mapserver/issues/4552
* https://github.com/mapserver/mapserver/issues/4553
I hope the second issue is clear to you as it seems I was not clear in my
previous email.
Y.
2012/12/19 Umberto Nicoletti <umberto.nicoletti at gmail.com>
> On Mon, Dec 17, 2012 at 10:08 PM, Yves Jacolin <
> yves.jacolin at camptocamp.com> wrote:
>> Hello,
>> Currently working with python mapscript on outputformat object, I have
>> some difficulties to get the correct information.
>> First, I can't get outputformat list from map obj. The documentation says:
>> outputformatlist : outputFormatObj[]
>> Array of the available output formats.
>> Note
>> Currently only available for C#. A proper typemaps should be implemented
>> for the other languages.
>> And indeed, even if the method appears, this is not working.
> I have done a quick test in python and java and it seems to return just
> one (selected?) outputformatObj.
> Please open an issue.
>> Second, I can't get config option list without knowing the options. I can
>> use getOption( name, value ) method but it suppose to know the config name.
>> Am I wrong somewhere? Do you know a method to get this information or do
>> I need to fill a ticket?
> Assuming you're referring to MS_IMAGEMODE_* the option name and values are
> present in the mapscript module. I am not sure there is a way to enumerate
> them.
> Open an issue for that too and I'll make sure to have a look at them.
> Cheers,
> Umberto
> Thanks,
>> Y.
>> Responsable Formation et Support
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel (France) : +33 4 79 26 57 98
>> Tel (Suisse) : 02 16 190 10 43 (new)
>> Mob. : +33 6 18 75 42 21
>> Fax : 04 79 70 15 81
>> Mail : yves.jacolin at camptocamp.com
>> http://www.camptocamp.com
>> <yves.jacolin at camptocamp.com>
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121228/b94a98b0/attachment.html>
