[mapserver-dev] Docs externals checkout
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Feb 6 09:15:44 EST 2012
Sorry about that Howard, svn:externals requires a local Subversion of
1.6 or greater.
-jeff
On 12-02-03 11:06 AM, Howard Butler wrote:
> Jeff,
> Every time I check out the docs tree, including a clean checkout, I get a complaint:
>> svn: URL 'https://svn.osgeo.org/mapserver/trunk/mapserver/MIGRATION_GUIDE.txt' refers to a file, not a directory
> Is this the intended behavior?  I haven't followed in a while, but I remember some discussion about keeping the migration guide up higher in the tree instead of down in the docs. svn:external cannot refer to a single file as far as I know, and must instead refer to a directory.  To make the migration guide in the top of the tree work, would we need an external in the docs tree back to trunk?  We probably don't want that either...
