[mapserver-dev] Letterspacing is different for polyline labels
Daniel Morissette
dmorissette at mapgears.com
Mon Jul 30 10:38:58 PDT 2012
Do we know when the 1.25 factor was introduced and by who? My only
concern would be to not undo something that may have been done for a
good reason, otherwise I have no objection.
Daniel
On 12-07-30 12:50 PM, thomas bonfort wrote:
> Any objection in pushing this into 6.2 ? From all my tests, there were
> no more or no less inter-character collisions when reducing the
> letterspacing, and it has the added advantage of a consistent output
> between ANGLE AUTO and ANGLE FOLLOW labels (follow labels fall back to
> "auto" mode when the line has only two vertices).
> regards,
> thomas
> On Tue, Jul 24, 2012 at 10:46 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us> wrote:
>> +1 on the change (it'll bust a few regression tests...)
>> Steve
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Oliver Tonnhofer
>> Sent: Tuesday, July 24, 2012 9:34 AM
>> To: mapserver-dev at lists.osgeo.org
>> Subject: [mapserver-dev] Letterspacing is different for polyline labels
>> Hi,
>> while comparing the rendering of Mapnik and Mapserver I found out that the letter spacing of line labels is much larger with Mapserver.
>> After diving into the source code, I found out that labels on a straight line are rendered differently than on curved lines. As mentioned in #4026, the inter-character spacing is defined in the font itself, but that spacing is multiplied by 1.25 when a label is rendered on a polyline.
>> See: https://github.com/mapserver/mapserver/blob/master/mapprimitive.c#L1818
>> Here you can see how "Alter Wall" and "Neuer Wall" are rendered with different spacing. "Alter Wall" is on a straight line, while "Neuer Wall" is on a curved line.
>> https://dl.dropbox.com/u/2633201/issues/mapserver/letterspacing-125.png
>> Changing the letterspacing to 1.0 in mapprimitive.c makes the rendering more similar:
>> https://dl.dropbox.com/u/2633201/issues/mapserver/letterspacing-100.png
>> The output is now also quite similar to the output of Mapnik (after adapting the fontsize).
>> I've created a ticket for that issue: https://github.com/mapserver/mapserver/issues/4404
>> Regards,
>> Oliver
>> Oliver Tonnhofer | Omniscale GmbH & Co KG | http://omniscale.de
>> http://mapproxy.org | https://github.com/olt | @oltonn
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
