[mapserver-dev] Google Raster in Map Server Path to Png
djaevi juanpablo26_02 at hotmail.com
Fri Jun 8 06:15:57 PDT 2012
Hi to all, im trying to export a layer to PNG using this path.
http://www.mapaintegral.com.ar/cgi-bin/mapserv?map=/home/www/vhosts/mapaintegral.com.ar/httpdocs/DATA/mapfiles/afis.map&layer=E_Puntos&SERVICE=WMS&Version=1.1.1&mode=map&FORMAT=image%2Fpng
If you follow the link you can see the mapserver layer created with arcgis.
All works great but i want to know if exists any way or parameter to add a
google map layer as base. For example
*&base=googlehybrid* or something like that.
Thanks a lot and excuse me for my bad english
Regards
View this message in context: http://osgeo-org.1560.n6.nabble.com/Google-Raster-in-Map-Server-Path-to-Png-tp4979969.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
