[mapserver-dev] error in php_mapscript_util.c
Ivo Karabojkov karabojkov at kit-bg.com
Tue Jun 19 09:52:16 PDT 2012
Thank you for your kind reply! I'm not familiar with git usage but I'll do my
best to test during next days.
If the problem is caused by PHP 5.4 I can also try existing port with PHP
5.3
Jeff McKenna wrote
> On 12-06-17 4:13 PM, Ivo Karabojkov wrote:
>> Almost same for me. I am trying to compile form PORTS on freeBSD 9.0, PHP
>> version 5.4.3
>> Ported version of MapServer is mapserver-6.0.1_5
>> The error is the same:
>> php_mapscript_util.c: In function 'mapscript_object_new':
>> php_mapscript_util.c:45: error: 'zend_class_entry' has no member named
>> 'default_properties'
>> php_mapscript_util.c: In function 'mapscript_object_new_ex':
>> php_mapscript_util.c:62: error: 'zend_class_entry' has no member named
>> gmake[1]: *** [php_mapscript_util.o] Error 1
>> Is there any way to fix this?
>> Thanks in advance!
> Actually I fixed this about a month ago, you will have to use MapServer
> git-master to get it for now though, as it will be in the upcoming 6.2
> release.  If you want to test the changes please do so and provide
> feedback at https://github.com/mapserver/mapserver/issues/4309
> Thank you.
> -jeff
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-in-php-mapscript-util-c-tp4654681p4982466.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
