[mapserver-dev] php mapscript doesn't work with php 5.4.0
Jan Hartmann j.l.h.hartmann at uva.nl
Tue May 8 09:54:13 EDT 2012
Not sure if this is a general problem, but when I upgraded php from
5.3.8 to 5.4.0, php_mapscript.so refused to load, even after recompiling
mapserver:
PHP Warning:  PHP Startup: Unable to load dynamic library
'/local/lib/php/extensions/php_mapscript.so' -
/local/lib/php/extensions/php_mapscript.so: undefined symbol:
output_globals in Unknown on line 0, referer:
http://mapserver.sara.nl/bonne_vect2/test
Can anyone confirm before I submit a bug?
Jan
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120508/1ce2497a/attachment.html
