[mapserver-dev] 6.0.3 (was: 6.2) release
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Fri May 18 09:26:45 EDT 2012
+1 as well...
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of Daniel Morissette [dmorissette at mapgears.com]
Sent: Friday, May 18, 2012 8:12 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] 6.0.3 (was: 6.2) release
On 12-05-18 8:22 AM, Jeff McKenna wrote:
> Is there any interest to push out a 6.0.3 release today, to coincide
> with the GDAL 1.9.1 release?   I mean interest other than my own :)   My
> thinking is that it would be good to do before the North American summer
> holidays start.
+1 since there seem to be a good set of changes in the GIT branch (see
below).
I guess I should take care of it as release manager of the 6.0 branch.
I'll see if I can get to that today.
Daniel
Current Version (future 6.0.3, SVN branch-6-0):
- Fix creation of a vector symbolObj in mapscript (#4318)
- Added coverage metadata in WCS (#4306)
- Adjusted WCS 2.0 GetCapbilities response (#4003)
- Ignore unknown requets parameteres in WCS 2.0 (#4307).
- Fixed mapscript is unusable in a web application due to memory leaks
(#4262)
- Fixed getFeature request with custom output format fails on filter
encoding (#4190)
- Fixed resolution when UoM changes in WCS 2.0 (#4283)
- Added missing DEFRESOLUTION parameter to msCopyMap() function (#4272)
- Fixed Python MapScript layerObj/classObj Error (#3940)
- Fixed WCS 2.0 axis order, offset vector, and origin (#4006, #4191)
- Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
- Added MS_CJC_* constants in PHP/MapScript (#4183)
- Fixed Memory leak with fribidi strings (#4188)
- Added missing properties in styleObj setter of PHP/MapScript (#3901)
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
