[mapserver-dev] 6.0.3 (was: 6.2) release
Martin Kofahl M.Kofahl at gmx.net
Fri May 18 14:22:16 EDT 2012
Hi Daniel -
consider #4273 too, please.
Kind regards
Martin
-------- Original-Nachricht --------
> Datum: Fri, 18 May 2012 09:12:06 -0400
> Von: Daniel Morissette <dmorissette at mapgears.com>
> An: mapserver-dev at lists.osgeo.org
> Betreff: Re: [mapserver-dev] 6.0.3 (was: 6.2) release
> On 12-05-18 8:22 AM, Jeff McKenna wrote:
> > Is there any interest to push out a 6.0.3 release today, to coincide
> > with the GDAL 1.9.1 release?   I mean interest other than my own :)   My
> > thinking is that it would be good to do before the North American summer
> > holidays start.
> +1 since there seem to be a good set of changes in the GIT branch (see
> below).
> I guess I should take care of it as release manager of the 6.0 branch.
> I'll see if I can get to that today.
> Daniel
> Current Version (future 6.0.3, SVN branch-6-0):
> - Fix creation of a vector symbolObj in mapscript (#4318)
> - Added coverage metadata in WCS (#4306)
> - Adjusted WCS 2.0 GetCapbilities response (#4003)
> - Ignore unknown requets parameteres in WCS 2.0 (#4307).
> - Fixed mapscript is unusable in a web application due to memory leaks
> (#4262)
> - Fixed getFeature request with custom output format fails on filter
> encoding (#4190)
> - Fixed resolution when UoM changes in WCS 2.0 (#4283)
> - Added missing DEFRESOLUTION parameter to msCopyMap() function (#4272)
> - Fixed Python MapScript layerObj/classObj Error (#3940)
> - Fixed WCS 2.0 axis order, offset vector, and origin (#4006, #4191)
> - Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
> - Added MS_CJC_* constants in PHP/MapScript (#4183)
> - Fixed Memory leak with fribidi strings (#4188)
> - Added missing properties in styleObj setter of PHP/MapScript (#3901)
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
