[mapserver-dev] call for vote on RFC 82
Tom Kralidis tomkralidis at hotmail.com
Fri Oct 5 10:02:15 PDT 2012
Daniel, thanks for the info.  It should have.  I believe they are updated every two hours on the odd hour.  Thomas?
In the meantime, the update is at https://github.com/mapserver/docs/commit/3badaeae353fb0a175266c1df9c0a3b9c9ed327c
..Tom
> Date: Fri, 5 Oct 2012 12:56:17 -0400
> From: dmorissette at mapgears.com
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] call for vote on RFC 82
> Thank you Tom.
> BTW, I don't see the changes in the version of the doc on the website.
> Should it not have updated automatically?
> Daniel
> On 12-10-05 10:55 AM, Tom Kralidis wrote:
> >  > Date: Thu, 4 Oct 2012 22:20:56 -0400
> >  > I am sorry for not commenting on this earlier. I am generally +1 on this
> >  > addition, I'd just suggest a few changes to the RFC text to ease the
> >  > life of our users:
> >  > - Explicitly indicate that the layer GetMetadata param is optional and
> >  > if not provided then the service metadata is returned (this is what the
> >  > pseudo-code suggests, did I read it right?)
> > Correct.  RFC updated.
> >  > - Add some usage examples, i.e. mapfile snippets and sample requests
> >  > showing the various possible use cases ... that will serve as docs until
> >  > officially documented
> > Done.
> >  > - There is no mention of docs. What's the plan on that front?
> > Added Documentation section in RFC.  And Testing.
> >  > Also, a general question: does any other OWS server handle this the same
> >  > way (i.e. with a vendor-specific GetMetadata)? If yes then it would be
> >  > great to have references in the introduction.
> > GetMetadata is not a vendor specific parameter by any means.  Many OWS
> > servers allow for specification of a metadata url, like MapServer does,
> > but not to dynamically generate metadata XML like this RFC.
> > Having said this, it appears that GeoServer is building CSW server
> > support, which serves the same requirement as this RFC in terms of
> > advertising metadata XML for layers on the fly.  Not that I'm proposing
> > this for MapServer (I'd recommend pycsw :) ), but from the Capabilities
> > XML perspective, the metadata XML URLs are opaque, which leaves us to
> > our own devices to generate these (either canned as we support now, or
> > per this RFC).
> > Thanks
> > ..Tom
> >  > Thanks
> >  > Daniel
> >  > On 12-10-03 12:27 PM, Tom Kralidis wrote:
> >  > > Thanks for the comments and suggestions for this RFC.
> >  > > I would like to call for vote on RFC 82:
> >  > > http://mapserver.org/trunk/development/rfc/ms-rfc-82.html
> >  > > https://github.com/mapserver/mapserver/pull/4486
> >  > > +1
> >  > > ..Tom
> >  > > _______________________________________________
> >  > > mapserver-dev mailing list
> >  > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >  > Daniel Morissette
> >  > http://www.mapgears.com/
> >  > Provider of Professional MapServer Support since 2000
> Daniel Morissette
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121005/6dbc3f47/attachment-0001.html>
