[mapserver-dev] WFS Filter encoding issue
Bart van den Eijnden bartvde at osgis.nl
Tue Sep 11 01:51:05 PDT 2012
Yves,
what does your FILTER parameter look like in the MAP file? What if you include the <Filter> tags in there? I think MapServer would skip adding them with <ogc:Filter>.
Which would make GeoServer happy, but not sure about ArcGIS.
Otherwise I would change the following line in MapServer code to use xmlns:ogc:
https://github.com/mapserver/mapserver/blob/master/mapwfslayer.c#L152
Best regards,
Bart
OSGIS - http://osgis.nl
On Sep 11, 2012, at 10:43 AM, Yves Jacolin <yves.jacolin at camptocamp.com> wrote:
> ticket on github is: https://github.com/mapserver/mapserver/issues/3414
> Y.
> 2012/9/11 Yves Jacolin <yves.jacolin at camptocamp.com>
> Le 11/09/2012 10:31, Bart van den Eijnden a écrit :
> Hey Yves,
> I think it makes sense to file a ticket for this.
> Best regards,
> Bart
> Ok looking more carefully in the bugtracker I find this ticket http://trac.osgeo.org/mapserver/ticket/3414
> which looks similar. We have the same issue with arcgis WFS service.
> To give more details: we are doing some testing on MapServer and GeoServer WFS services and our customer is testing ArcGIS WFS service.
> Both GeoServer and ArcGIS services give same results (error using ogc namespace without xmlns:ogc).
> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120911/7c2817ab/attachment.html>
