[mapserver-dev] WFS Filter encoding issue
Eichner, Andreas - SID-NLKM Andreas.Eichner at sid.sachsen.de
Wed Sep 12 02:28:19 PDT 2012
you might try appending a NAMESPACE parameter: http://jira.codehaus.org/browse/GEOT-1740 This is intended to support the TYPENAME parameter when using namespace qualified type names but depending on the implementation it might help for the FILTER too.
> Does anyone knows if it Is a MS issue?
Basically yes. Using namespace qualified XML requires namespace declaration.
hth
