[mapserver-dev] MS RFC 89 - Layer Geomtransform
Alan Boudreault aboudreault at mapgears.com
Tue Feb 12 06:05:35 PST 2013
Thanks Daniel, I've added the info, should be updated in an hour or so.
Alan
On 13-02-08 04:58 PM, Daniel Morissette wrote:
> On 13-02-05 2:11 PM, Alan Boudreault wrote:
>> I have added a new RFC document proposing the support of geomtransform
>> at the layer level. It also adds 3 new geomtransforms: simplify,
>> simplifypt and generalize.
>> http://mapserver.org/trunk/development/rfc/ms-rfc-89.html
> Hi Alan,
> In the Mapscript section, should we add a mention that we'll have to add
> the ability to get/set the layer-level GEOMTRANSFORM values? I presume
> this was implied, but better explicitly mention it.
> Also, I'd suggest adding links to the docs of the two GEOS algorithms in
> section 3 (the links that you sent to Jan in this thread earlier).
> And finally, the numbering of sections 6 to 9 is off by one.
> Thanks!
Alan Boudreault
http://www.mapgears.com/
