[mapserver-dev] Template driven output - issue with PostGIS connection
Havard Tveite havard.tveite at umb.no
Thu Jun 6 07:06:00 PDT 2013
I am not sure what you are after.  But here is some information:
Outputformat:
   OUTPUTFORMAT
     NAME "OGR_GeoJSON"
     DRIVER "OGR/GeoJSON"
     FORMATOPTION "STORAGE=stream"
     FORMATOPTION "FORM=simple"
   END
Layer template:
    TEMPLATE "dummy"
Håvard
On 6/6/2013 3:54 PM, thomas bonfort wrote:
> ok... what template are you using?
> [id] maps to the process id of the mapserver instance. are you using that instead of [shpidx] ?
> thomas
> On 6 June 2013 15:50, Havard Tveite <havard.tveite at umb.no <mailto:havard.tveite at umb.no>> wrote:
>     The OGR based GeoJSON option seems OK.  No trouble
>     with the "using unique" attribute there.
>     Håvard
>     On 6/6/2013 2:00 PM, Smith, Michael ERDC-RDE-CRREL-NH wrote:
>         You could also try to isolate it to the template output by trying ogr
>         based geojson output (http://mapserver.org/output/__ogr_output.html <http://mapserver.org/output/ogr_output.html>)
>         OUTPUTFORMAT
>             NAME "OGR_GeoJson"
>             DRIVER "GeoJson"
>         END
>         Mike
>         On 6/6/13 7:49 AM, "Havard Tveite" <havard.tveite at umb.no <mailto:havard.tveite at umb.no>> wrote:
>             I have not tried with other data sources, so this may not be
>             PostGIS related.
>             I have sent Thomas the information from the PostgreSQL logs
>             (the queries seemed to be the same for GML and geojson).
>             Håvard
>             On 6/6/2013 1:26 PM, thomas bonfort wrote:
>                 Havard,
>                 The postgis driver hasn't changed in trunk since 6.2. Can you enable
>                 debugging on your postgis layer and post the query that is being sent to
>                 the postgres backend?
>                 regards,
>                 thomas
>                 On 6 June 2013 13:17, Havard Tveite <havard.tveite at umb.no <mailto:havard.tveite at umb.no>
>                 <mailto:havard.tveite at umb.no <mailto:havard.tveite at umb.no>>> wrote:
>                       I have a PostGIS connection, and want to provide GeoJSON
>                       output.
>                       After some stumbling (and updating of the Mapserver docs!),
>                       I got it to work, except for the "using unique" part.
>                       The interesting parts of my DATA string is like:
>                            DATA "geom from (select x.id <http://x.id> <http://x.id> as id, ...) as test
>                 using unique id using SRID=4326"
>                       This works well for WFS with GML, but when I add
>                       "&outputformat=geojson" (to get GeoJSON output), the returned
>                       id is a very large number (for instance 137051404431549 - it
>                       changes for each request), and it is the same number for all
>                       the features.  The actual ids are between 1 and 1000.
>                       I have the same issue when not using WFS
>                 (&mode=nquery&qformat=geojson)____.
>                       My template for geojson output is according to the documentation
>                       (and everything else is returned as it should).
>                       Could this be a bug?
>                       mapserv -v
>                       MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>                 SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>                 SUPPORTS=OPENGL SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>                 SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>                 SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>                 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>                       I have not checked trunk.
>                       Håvard
>                       Håvard Tveite
>                       Department of Mathematical Sciences and Technology, UMB
>                       Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>                       Phone: +47 64965483 <tel:%2B47%2064965483> <tel:%2B47%2064965483> Fax: +47 64965401 <tel:%2B47%2064965401>
>                 <tel:%2B47%2064965401> http://www.umb.no/imt/
>                       ___________________________________________________
>                       mapserver-dev mailing list
>                 mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org> <mailto:mapserver-dev at lists.__osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>
>                 http://lists.osgeo.org/____mailman/listinfo/mapserver-dev <http://lists.osgeo.org/__mailman/listinfo/mapserver-dev>
>                 <http://lists.osgeo.org/__mailman/listinfo/mapserver-dev <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>__>
>             Håvard Tveite
>             Phone: +47 64965483 <tel:%2B47%2064965483> Fax: +47 64965401 <tel:%2B47%2064965401> http://www.umb.no/imt/
>     Håvard Tveite
Håvard Tveite
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
