[mapserver-dev] Pull requests in documentation
thomas bonfort thomas.bonfort at gmail.com
Thu Nov 28 05:17:07 PST 2013
Dear documentation team,
Thomas and the french translation team have put sufficient effort in
this enhancement to not be left in the dark with no reaction to their
proposal. Their pull request is now two months old, but the actual
implementation and ideas started off nearly two years ago and were
already left in limbo back then.
If there are no technical or philosophical objections as to why this
enhancement should not be merged, I suggest we accept the changes, and
ask them to take responsibility for it. In any case, it is neither
good for them or for the mapserver project to leave things in the
current state.
regards,
thomas
On 28 October 2013 22:50, Thomas Gratier <osgeo.mailinglist at gmail.com> wrote:
> Hi,
> I'm always waiting for my PR to be merged.
> Any new about this?
> Jeff, did you try to build the French documentation using my branch?
> It's a 10 min try FYI.
> Thanks for your feedback
> Cheers
> Thomas
> 2013/10/14 Thomas Gratier <osgeo.mailinglist at gmail.com>
>> Hi,
>> Thanks for the first feedback.Can you tell where are the "english
>> misleading"? I want to make required modifications to make things more
>> clear.
>> Thanks
>> Thomas
>> 2013/10/13 Yves Jacolin <yves.jacolin at camptocamp.com>
>>> Thomas,
>>> I built the french translation on my system which seems quiet simple
>>> and your doc is enought to find the good way (except some english
>>> misleading).
>>> Thanks,
>>> Y.
>>> 2013/10/12 Thomas Gratier <osgeo.mailinglist at gmail.com>:
>>> > Hi,
>>> > It's done. Before i submit another PR for the documentation, you can go
>>> > to
>>> > my repository https://github.com/ThomasG77/docs.git and checkout my
>>> > branch
>>> > branch-6-4-i18n-with-po
>>> > After, do the usual build (you need the latest Sphinx version) with
>>> > make
>>> > html to see the documentation content about documentation.
>>> > Then, follow the instructions you have in the built html to enable the
>>> > i18n
>>> > translation process.
>>> > If you have any feedbacks, you can do it via a Github issue , a PR or
>>> > in
>>> > this thread.
>>> > At the end, when everything will be Ok, I will make a new PR from my
>>> > branch,
>>> > for the documentation on documentation process.
>>> > Regards
>>> > Thomas Gratier
>>> > 2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
>>> >> Ok thank you Thomas.
>>> >> -jeff
>>> >> On 2013-10-10 12:58 PM, Thomas Gratier wrote:
>>> >> > Hi,
>>> >> > Jeff, Yves, I will finish and push the docs about the new system
>>> >> > this
>>> >> > week.
>>> >> > Thomas Gratier (author of the two mentioned PR)
>>> >> > 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
>>> >> > <mailto:yves.jacolin at camptocamp.com>>
>>> >> >     Thanks Jeff!
>>> >> >     Y.
>>> >> >     <mailto:jmckenna at gatewaygeomatics.com>>:
>>> >> >     > I want to test this before merging.  I will do so and get back
>>> >> > to
>>> >> > you.
>>> >> >     > -jeff
>>> >> >     > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
>>> >> >     >> Hello,
>>> >> >     >> There are 4 pull requests [1] whit 2 of them look important
>>> >> > to me
>>> >> >     (I18n system
>>> >> >     >> and i18n pot file) as it can help to improve the translation
>>> >> > process.
>>> >> >     >> QGIS is using such system successfully with transiflex app
>>> >> > which
>>> >> >     helps to get
>>> >> >     >> website and documentation translated really fast.
>>> >> >     >> I do think that this 2 PR are worth to be merged into master
>>> >> > branch.
>>> >> >     >> I would like to get your opinion (Jeff :) ) on this, may be
>>> >> > we
>>> >> >     can run a short
>>> >> >     >> vote after discussion. I know that there are some discussion
>>> >> > on
>>> >> >     this on the
>>> >> >     >> FOSS4G code sprint but may be a broader discussion could
>>> >> > help.
>>> >> >     >> Thanks, :)
>>> >> >     >> Y.
>>> >> >     >> [1] https://github.com/mapserver/docs/pulls
>>> >> >     > _______________________________________________
>>> >> >     > mapserver-dev mailing list
>>> >> >     > mapserver-dev at lists.osgeo.org
>>> >> > <mailto:mapserver-dev at lists.osgeo.org>
>>> >> >     > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> >> >     Responsable Formation et Support
>>> >> >     Camptocamp France SAS
>>> >> >     Savoie Technolac, BP 352
>>> >> >     73377 Le Bourget du Lac, Cedex
>>> >> >     Tel (France) : +33 4 79 26 57 98
>>> >> > <tel:%2B33%204%2079%2026%2057%2098>
>>> >> >     Tel (Suisse) : 021 619 10 43
>>> >> >     Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
>>> >> >     Fax : 04 79 70 15 81
>>> Mail : yves.jacolin at camptocamp.com
>>> http://www.camptocamp.com
