[mapserver-dev] Pull requests in documentation
Thomas Gratier osgeo.mailinglist at gmail.com
Mon Oct 14 09:37:53 PDT 2013
Thanks for the first feedback.Can you tell where are the "english
misleading"? I want to make required modifications to make things more
clear.
Thanks
Thomas
2013/10/13 Yves Jacolin <yves.jacolin at camptocamp.com>
> Thomas,
> I built the french translation on my system which seems quiet simple
> and your doc is enought to find the good way (except some english
> misleading).
> Thanks,
> Y.
> 2013/10/12 Thomas Gratier <osgeo.mailinglist at gmail.com>:
> > Hi,
> > It's done. Before i submit another PR for the documentation, you can go
> to
> > my repository https://github.com/ThomasG77/docs.git and checkout my
> branch
> > branch-6-4-i18n-with-po
> > After, do the usual build (you need the latest Sphinx version) with make
> > html to see the documentation content about documentation.
> > Then, follow the instructions you have in the built html to enable the
> i18n
> > translation process.
> > If you have any feedbacks, you can do it via a Github issue , a PR or in
> > this thread.
> > At the end, when everything will be Ok, I will make a new PR from my
> branch,
> > for the documentation on documentation process.
> > Regards
> > Thomas Gratier
> > 2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> >> Ok thank you Thomas.
> >> -jeff
> >> On 2013-10-10 12:58 PM, Thomas Gratier wrote:
> >> > Hi,
> >> > Jeff, Yves, I will finish and push the docs about the new system this
> >> > week.
> >> > Thomas Gratier (author of the two mentioned PR)
> >> > 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
> >> > <mailto:yves.jacolin at camptocamp.com>>
> >> >     Thanks Jeff!
> >> >     Y.
> >> >     <mailto:jmckenna at gatewaygeomatics.com>>:
> >> >     > I want to test this before merging.  I will do so and get back
> to
> >> > you.
> >> >     > -jeff
> >> >     > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
> >> >     >> Hello,
> >> >     >> There are 4 pull requests [1] whit 2 of them look important to
> me
> >> >     (I18n system
> >> >     >> and i18n pot file) as it can help to improve the translation
> >> > process.
> >> >     >> QGIS is using such system successfully with transiflex app
> which
> >> >     helps to get
> >> >     >> website and documentation translated really fast.
> >> >     >> I do think that this 2 PR are worth to be merged into master
> >> > branch.
> >> >     >> I would like to get your opinion (Jeff :) ) on this, may be we
> >> >     can run a short
> >> >     >> vote after discussion. I know that there are some discussion on
> >> >     this on the
> >> >     >> FOSS4G code sprint but may be a broader discussion could help.
> >> >     >> Thanks, :)
> >> >     >> Y.
> >> >     >> [1] https://github.com/mapserver/docs/pulls
> >> >     > _______________________________________________
> >> >     > mapserver-dev mailing list
> >> >     > mapserver-dev at lists.osgeo.org
> >> > <mailto:mapserver-dev at lists.osgeo.org>
> >> >     > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >> >     Responsable Formation et Support
> >> >     Camptocamp France SAS
> >> >     Savoie Technolac, BP 352
> >> >     73377 Le Bourget du Lac, Cedex
> >> >     Tel (France) : +33 4 79 26 57 98<tel:%2B33%204%2079%2026%2057%2098>
> >> >     Tel (Suisse) : 021 619 10 43
> >> >     Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
> >> >     Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131014/e6c6f844/attachment.html>
