[mapserver-dev] Rethinking our doc site build workflow (+vote)
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Apr 5 06:42:29 PDT 2014
True Stephan, I've heard from Jorge Sanz for a while how useful
readthedocs is for a project, we should investigate that option as well.
-jeff
On 2014-04-05, 7:13 AM, Stephan Meißl wrote:
> Read the Docs would support the automatic generation of pdfs [1]
> triggered via GitHub webhooks.
> cu
> Stephan
> [1]
> http://read-the-docs.readthedocs.org/en/latest/features.html#pdf-generation
> On 04/05/2014 12:08 PM, Yves Jacolin wrote:
>> Hello
>> The main concern is the build of pdf. May be we can build them outside
>> the server when we update po files and push it to git or somewhere else.
>> This will not an automatic build so I am not fan of this solution but
>> the pdf build is the one that cause so much trouble.
>> Y.
>> Le 5 avr. 2014 11:44, "Stephan Meißl" <stephan at meissl.name
>> <mailto:stephan at meissl.name>> a écrit :
>>     +1
>>     We could even investigate using "Read the Docs" [1] which offers a nice
>>     service for building and hosting documentation.
>>     cu
>>     Stephan
>>     [1] https://readthedocs.org/
>>     On 04/04/2014 10:55 PM, thomas bonfort wrote:
>>     > PSC,
>>     > In light of the recent projectsvm downtime and the (increasing, given
>>     > the new translations) load we are putting on that server while
>>     > building our docs, I would like to propose that we transition our
>>     > build process to use travis-ci for the compilation part.
>>     > In clear, docs would be automatically built on travis-ci.org
>>     <http://travis-ci.org> once a
>>     > commit is pushed on the stable or master branch, and would then be
>>     > scp'd/rsync'd to the public projectvm directory on success.
>>     > Advantages:
>>     > - no need to maintain build scripts on the projectsvm
>>     > - the actual travis config files are simple and minimal:
>>     https://github.com/tbonfort/docs/commit/1d178ab6e6d0765adfbb0fea40404a6a1803a969
>>     > (without the logic to publish to mapserver.org
>>     <http://mapserver.org> yet, though)
>>     > Inconveniences:
>>     > - we rely on an external service we have no control on. we can always
>>     > switch back to the current solution if needed (no
>>     www.mapserver.org <http://www.mapserver.org>
>>     > downtime, the docs would just not be in sync while we transitioned).
>>     > - building the PDFs has a non-negligeable impact on build times and
>>     > apt packages needed to be installed on the travis instances. They
>>     > would therefore be disabled by default, but might be enabled on a
>>     > case-by-case basis if the commit message contains a magic keyword.
>>     > - it might seem we are loosing control as to what is published on the
>>     > mapserver.org <http://mapserver.org> website (given the resulting
>>     website is automatically
>>     > published). In practice this is more or less already the case with the
>>     > automatic builds happening on the projectsvm.
>>     > I've had confirmation from the travis team that we are not abusing
>>     > their system by implementing this:
>>     > Hey Thomas,
>>     > Thanks for getting in touch and checking with us!
>>     > We absolutely don't mind you using our service to build and push your
>>     > documentation site, quite the opposite.
>>     > We're always happy to see people adopt Travis CI in unexpected and new
>>     > ways, so by all means, ship it!
>>     > Cheers, Mathias
>>     > Mathias Meyer
>>     > Before investing more time on this, I will need a go from the PSC. I'm
>>     > going to be offline next week and unable to respond, but will start
>>     > the transition at my return if no -1s are casted.
>>     > +1 Use Travis-ci platform to build and publish mapserver website
>>     > best regards,
>>     > thomas
>>     _______________________________________________
>>     mapserver-dev mailing list
>>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
