[mapserver-dev] FW: [mapserver-users] WMS request fails when spaces are encoded as plus symbol in query part of URL
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Aug 20 10:07:33 PDT 2014
I agree it's a change that should slip in now for 7.0, but I hope those
with later ArcServer versions can test it in the beta (or we have one
volunteer to let us use their Arc WMS instance for testing).
-jeff
On 2014-08-20 1:52 PM, Lime, Steve D (MNIT) wrote:
> Devs: Is this a change that we should make for 7.0? Seems reasonable but
> I’m not sure what the side effects might be.
> Steve
> *From:*Moen, Paul T. [mailto:pmoen at nd.gov]
> *Sent:* Wednesday, August 20, 2014 9:44 AM
> *To:* Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] WMS request fails when spaces are
> Steve,
> You are right about the outcome of 1 and 2.  1 encodes the % and 2
> throws the following error.
> msBuildWMSLayerURLBase(): One of wms_onlineresource, wms_server_version,
> wms_name metadata is missing in layer USGS DRG 250k Topo Maps.  Please
> either provide a valid CONNECTION URL, or provide those values in the
> layer's metadata.\n\n
> I found the function as you said and
> I removed the
>   if (*i == ' ')
>        *j = '+';
>      else
> from the function then recompiled.
>     char *msEncodeUrlExcept(const char *data, const char except)
>        char *hex = "0123456789ABCDEF";
>        const char *i;
>        char  *j, *code;
>        int   inc;
>        unsigned char ch;
>        for (inc=0, i=data; *i!='\0'; i++)
>          if (msEncodeChar(*i))
>            inc += 2;
>        code = (char*)msSmallMalloc(strlen(data)+inc+1);
>        for (j=code, i=data; *i!='\0'; i++, j++) {
>          if ( except != '\0' && *i == except ) {
>            *j = except;
>          } else if (msEncodeChar(*i)) {
>            ch = *i;
>            *j++ = '%';
>            *j++ = hex[ch/16];
>            *j   = hex[ch%16];
>          } else
>            *j = *i;
>        *j = '\0';
>        return code;
> Everything works again after a mapserver recompile, install and finally
> a restart of apache.  Thanks so much for the path to the solution.
> Paul Moen
> pmoen at nd.gov <mailto:pmoen at nd.gov>
> 701-328-2434
> *From: *<Lime>, "Steve D (MNIT)" <Steve.Lime at state.mn.us
> <mailto:Steve.Lime at state.mn.us>>
> *Date: *Wednesday, August 20, 2014 at 12:41 AM
> *To: *Paul Moen <pmoen at nd.gov <mailto:pmoen at nd.gov>>,
> "mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>"
> <mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>>
> *Subject: *RE: [mapserver-users] WMS request fails when spaces are
> Hmmm... Nice backwards compatibility ESRI. The +'s seem to still be
> quite legal (http://tools.ietf.org/html/rfc3986 and other references) in
> the query string (but not the path). I don't have access to test and I'm
> guessing these ideas won't work but they might be worth a quick try:
>    1) Try encoding the wms_name in the metadata: "wms_name"
> "Topomap%20DRG%20250k"
>    2) Don't set the wms_name in the metadata but add it to the
> connection: CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap%20DRG%20250k&"
> I'm betting MapServer will encode the %'s in 1 and throw an error in 2.
> Otherwise you could hack the MapServer source. Function is called
> msEncodeUrlExcept() in mapstring.c you can see the section to change
> starting at line 1138 in git master
> (https://github.com/mapserver/mapserver/blob/master/mapstring.c)
> <https://github.com/mapserver/mapserver/blob/master/mapstring.c).>
> Maybe it's worth making this change as part of 7.0?
> Steve
> *From:*mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>] on behalf of Moen,
> Paul T. [pmoen at nd.gov <mailto:pmoen at nd.gov>]
> *Sent:* Tuesday, August 19, 2014 4:56 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] WMS request fails when spaces are encoded
> Hi all,
> We are consuming WMS services hosted by ESRI ArcGIS Server 10.0.  The
> server was upgraded to ArcGIS Server 10.2.2 and we no longer can access
> layer names with spaces.
> This is the server’s capabilities.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?request=GetCapabilities&service=WMS
> This is the layer I am using.
> LAYER
> # DEBUG 5
> CONNECTIONTYPE WMS
> CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?"
> METADATA
> "wms_name" "Topomap DRG 250k"
> "wms_format" "image/png"
> "wms_server_version" "1.1.1"
> "wms_srs" "EPSG:2266"
> END
> TYPE RASTER
> STATUS OFF
> NAME "USGS DRG 250k Topo Maps"
> END
> Mapserver encodes this request as follows.  Notice that the layer name,
> which is ‘Topomap DRG 250k’, is encoded with the spaces becoming the ‘+’
> character.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap+DRG+250k&REQUEST=map&WMTVER=1.0.0&SERVICE=WMS&FORMAT=image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BBOX=1906240.15992838,596656.333359479,2119730.85012732,789150.692893686&TRANSPARENT=TRUE&EXCEPTIONS=INIMAGE
> This returns the error in an image that says “Parameter ‘layers’
> contains unacceptable layer names.”
> When I replace the + in the layer name with %20, LAYERS=Topomap+DRG+250k
> become LAYERS=Topomap%20DRG%20250k and the request becomes the following.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap%20DRG%20250k&REQUEST=map&WMTVER=1.0.0&SERVICE=WMS&FORMAT=image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BBOX=1906240.15992838,596656.333359479,2119730.85012732,789150.692893686&TRANSPARENT=TRUE&EXCEPTIONS=INIMAGE
> That request works.  Obviously, ESRI is no longer decoding + as a space
> and therefore does not recognize the layer name with spaces.
> Is there any way I can have mapserver encode all characters using
> percent-encoding, or at least encode spaces as %20 instead of a + character.
> Thanks,
> Paul Moen
> 701-328-2434
