[mapserver-dev] missing files using built-in OpenLayers template
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 16 06:41:00 PDT 2014
Indeed that is the case for us: scriptName in our single file build was
set to OpenLayers.js, and then the img and theme folders were never
found.  I changed it to our custom 'OpenLayers-ms60.js' and now
style.css and all images are found.  Phew.  Mark as fixed!!!
-jeff
On 2014-06-16, 10:26 AM, Jeff McKenna wrote:
> I wonder if all this wonkiness is because we name our build something
> other than OpenLayers.js
> -jeff
> On 2014-06-16, 10:19 AM, Jeff McKenna wrote:
>> I had already changed the ImgPath, and I clear my cache constantly..no
>> this ImgPath change is in fact needed in our case for some reason.  (Now
>> i'm battling the missing style path also).  Looking...
>> -jeff
>> On 2014-06-16, 10:16 AM, thomas bonfort wrote:
>>> hmm, I was wondering why that wasn't needed beforehand. Actually the
>>> viewer works correctly with the lib files you added this morning, just
>>> make sure your browser cache is purged.
>>> thomas
>>> On 16 June 2014 15:06, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>> Oh interesting, I've never had to set that with single file builds..will
>>>> try now thanks!
>>>> -jeff
>>>> On 2014-06-16, 10:01 AM, thomas bonfort wrote:
>>>>> OpenLayers.ImgPath should probably be set to
>>>>> "http://www.mapserver.org/lib/" in our generated JS.
>>>>> On 16 June 2014 14:58, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>>>> Hi THomas,
>>>>>> Yes in fact I placed those files there this morning, the 'img' and
>>>>>> 'theme' folders were missing.
>>>>>> Correct, this single file build does not seem to be properly looking for
>>>>>> those files, it should be looking right in the same folder.
>>>>>> -jeff
>>>>>> On 2014-06-16, 9:55 AM, thomas bonfort wrote:
>>>>>>> Jeff,
>>>>>>> The files are present now (c.f.
>>>>>>> http://www.mapserver.org/lib/theme/default/) however there's something
>>>>>>> wrong with our generated javascript as it's requesting the theme files
>>>>>>> from http://server/cgi-bin/theme/default/style.css instead of
>>>>>>> www.mapserver.org/lib/...
>>>>>>> On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>>>>>> Still no luck, I would have thought that this OpenLayers single build
>>>>>>>> would look in the same directory for the img and theme folders.  Anyone
>>>>>>>> have any ideas?
>>>>>>>> -jeff
>>>>>>>> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>>>>>>>>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>>>>>>>>> I have no idea how the website and github are linked now, but I just
>>>>>>>>> poked around the ProjectsVM and found that js file, so I copied the img
>>>>>>>>> and theme folders there: http://www.mapserver.org/lib/  ...but still no
>>>>>>>>> luck.  Will keep looking.
>>>>>>>>> -jeff
>>>>>>>>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>>>>>>>>> You are right Jeff,
>>>>>>>>>> The openlayers script was missing in April and I asked that it would be put back.
>>>>>>>>>> It was recoverd but unfortunally the small images was not put back.
>>>>>>>>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>>>>>>>>> /Lars S.
>>>>>>>>>> -----Original Message-----
>>>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>>>>>>>>> Sent: den 16 juni 2014 00:32
>>>>>>>>>> To: 'MapServer Dev Mailing List'
>>>>>>>>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>>>>>>>>> Hello all,
>>>>>>>>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>>>>>>>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>>>>>>>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>>>>>>>>> pan) are broken.  Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>>>>>>>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>>>>>>>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>>>>>>>>> Thanks all!
>>>>>>>>>> -jeff
>>>>>>>>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
>>>>>>>>>> _______________________________________________
>>>>>>>> mapserver-dev mailing list
>>>>>>>> mapserver-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>>>> Jeff McKenna
>>>>>> MapServer Consulting and Training Services
>>>>>> http://www.gatewaygeomatics.com/
>>>> Jeff McKenna
Jeff McKenna
