[mapserver-dev] Missing svg symbol cause assert
François fblackburn at mapgears.com
Fri Mar 28 12:28:12 PDT 2014
After some debugging, I found out that there is no "ms_failure" returned
after the error declaration on line 911 of "mapcairo.c".
I will open up a ticket and submit a pull request.
François Blackburn
On 03/28/2014 01:51 PM, François wrote:
> Hi,
> While working on a map file, I found out that referencing to a missing
> svg file in a symbol definition cause an assert. The assert message
> says: "mapserv: (mapserver directory)/mapcairo.c:998:
> msRenderRasterizedSVGSymbol: Assertion
> `svg_cache->pixmap_buffer->height && svg_cache->pixmap_buffer->width'
> failed.".
> Is there already a ticket about this problem and if not, would it be
> worth it that I create one?
> Have a nice day.
> François Blackburn
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
