[mapserver-dev] build problem
Peter Freimuth peter.freimuth at blackbridge.com
Sun Sep 28 06:21:04 PDT 2014
Hi mapserver devs,
to verify that some of the bugfixes resolve two of the problems i currently have with map server i try to compile map server from scratch but whatever i tried i cannot resolve this problem:
[ 90%] Building CXX object CMakeFiles/mapserver.dir/mapscript/v8/v8_mapscript.cpp.o
Linking CXX shared library libmapserver.so
[ 90%] Built target mapserver
[ 91%] Building C object CMakeFiles/legend.dir/legend.c.o
Linking C executable legend
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to `hb_glib_script_from_script'
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to `hb_glib_script_to_script'
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to `hb_glib_get_unicode_funcs'
collect2: error: ld returned 1 exit status
make[2]: *** [legend] Error 1
make[1]: *** [CMakeFiles/legend.dir/all] Error 2
make: *** [all] Error 2
Seems that the headers or the lib of the  but  /usr/local/lib/libharfbuzz.so is available and i set -DCMAKE_PREFIX_PATH=/usr/local:/opt .
i used
cmake .. -DCMAKE_C_FLAGS="--coverage" -DCMAKE_CXX_FLAGS="--coverage" -DCMAKE_SHARED_LINKER_FLAGS="-lgcov" -DWITH_WCS=1 -DWITH_WFS=1 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1 -DWITH_PHP=0 -DWITH_PYTHON=1 -DWITH_JAVA=0 -DWITH_THREAD_SAFETY=1 -DWITH_FRIBIDI=1 -DWITH_FCGI=1 -DWITH_EXEMPI=1 -DCMAKE_BUILD_TYPE=Release -DWITH_RSVG=1 -DWITH_CURL=1 -DWITH_HARFBUZZ=1 -DWITH_POINT_Z_M=1 -DWITH_XMLMAPFILE=1 -DWITH_GEOS=1 -DWITH_POSTGIS=1 -DWITH_LIBXML2=1 -DWITH_OGR=1 -DWITH_GDAL=1 -DWITH_PROJ=1 -DWITH_GIF=1 -DWITH_GD=0 -DCMAKE_PREFIX_PATH=/usr/local:/opt -DFCGI_INCLUDE_DIR=/usr/include/fastcgi -DWITH_SVGCAIRO=0
on a vagrant ubuntu/trusty64
Mapserver was cloned from git master today.
__________________________________
Peter Freimuth
Manager - Software Development
Kurfürstendamm 22
10719 Berlin
Germany
Phone: +49 30 609 8300 - 100 (main) - 327 (direct)
www.blackbridge.com<http://www.blackbridge.com>
[cid:image001.png at 01CEDBBC.C2C97400]
The information contained herein is proprietary to BlackBridge and may not be used, reproduced or disclosed to others except as specifically permitted in writing by the originator of the information. The recipient of this information, by its retention and use, agrees to protect the same and the information contained therein from loss, theft and compromise. Any copies of this document, which are no longer required in company approved retention systems must be disposed of by means in which the trustee of the copy guarantee its complete destruction.
BlackBridge AG | Sitz Berlin | Amtsgericht Charlottenburg - Registergericht | HRB 152785 | Aufsichtsratsvorsitzender: David Westwood | Vorstand: Ryan Johnson
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140928/9c35928a/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140928/9c35928a/attachment-0001.png>
