[mapserver-dev] Default branch in github
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Aug 21 13:46:41 PDT 2015
I'd think users would want to work against the production branch (7.0) but people that fork would go off master. So either could be correct depending on perspective. What do other projects (e.g. GDAL) do? --Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Friday, August 21, 2015 2:58 PM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Default branch in github
The default branch in github is branch-7-0. Shouldn't that be master instead ?
Otherwise people that fork and hack are likely to use branch-7-0 instead of
master when submitting pull requests.
Even
http://www.spatialys.com
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
