[mapserver-dev] compiling question, Mr SID with gdal -> mapserver
Jukka Sirviö Jukka.Sirvio at mipro.fi
Wed Aug 26 07:23:00 PDT 2015
Hello,
First of all, thank you for the great product! Keep up the good work. Have been using Mapserver for over a decade now. I figure that the users group would not have answers for compiling related questions, so mailing the question here?
My question is that is there any decent advice / documentation / notes on compiling latest Mr SID SDK into gdal and to mapserver on CentOS? jp2 images decoding seems to work best when using Mr SID SDK. I'm able to compile the sdk into gdal, but with mapserver compilation there is no luck anymore (autoconf seems to work ok). Compiling without Mr SID, the other "basic" gdal & mapserver functionalities are working normally.
Thanks in advance!
Jukka Sirviö
Lead Designer
Water and Energy Management Systems
MIPRO OY
Kunnanmäki 9 | FI-50600 Mikkeli | Finland
Tel. +358 15 200 1213 | Mobile +358 44 749 1213 | Fax +358 15 200 1333
jukka.sirvio at mipro.fi<mailto:jukka.sirvio at mipro.fi> | http://www.mipro.fi<http://www.mipro.fi/>
Tavoitat asiantuntijamme yhden numeron ja sähköpostin kautta:
asiakastuki  044 749 1212  (8-16), asiakastuki at mipro.fi<mailto:asiakastuki at mipro.fi>.
Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista tietoa, joka on tarkoitettu
vain vastaanottajalleen. Jos et ole oikea vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta
virheestä ja tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu
käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
This message (including any attachments) may contain confidential information intended for
the person or entity to which it is addressed. If you are not the intended recipient, notify the
sender and delete this message immediately. Notice that disclosing, copying, distributing or any
other use of the message and its information, or taking any action based on it, is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150826/b04cd32f/attachment.html>
