[mapserver-dev] GSoC Ideas for MapServer
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Feb 23 07:15:23 PST 2015
On 2015-02-21 9:22 AM, Even Rouault wrote:
> Jeff,
> are you sure that WFS-T is part of Zoo-Project itself ? I can indeed see a
> demo on the website (only creation seems to work. update and delete seem to be
> broken), but coulnd't find the related source code in SVN (I did "grep -ri
> "insert" ." since the WFS-T operation to add a new feature is wfs:Insert, but
> no relevant match appeared. I tried other not successfull searches too). I may
> have missed something...
> Even
Even: Gérald responded to your question, I received it but I don't think
it made it to the mailing list.  Here it is below...
Thanks a lot Jeff for your support.
The WFS-T was indeed started a long time ago, historically prior to the
Barcelona event, I remember presenting it to the MapServer community
(through Daniel Morissette) with Nicolas during this event. At that time
I have a working version using the MapServer version available at that
time. We used it some time after for a client in production. But after
that we didn’t really maintain the code. I remember some time ago
thinking of concurrency gesture for instance for file based backend but
I do not remember implementing it  Anyway, the wfs-t source code is
available on the MapMint repository for a while now (since the last
OSGeo Code Sprint in Vienna, oops sorry the C-Tribe / QGIS Code Sprint I
should say … ). As we used the MapServer C-API for implementing the
WFS-T support and I know that it evolves a lot from one version to
another it is not really sure that the current code is working with the
current MapServer version. Obviously, by spending few times to check
what was the potential C-API changes it should be easy to fix it and
make it working again based on a modified version of the work made at
that time.
Best regards,
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
