[mapserver-dev] mapserver/mapscript crash due to _cairo_unscaled_font_fini
thomas bonfort thomas.bonfort at gmail.com
Thu Apr 21 06:24:25 PDT 2016
Worth,
I don't think we already have an issue opened for this, so please do go and
create one. If you can attach a testcase that exhibits the problem through
a plain shp2img or mapserv call (i.e. not mapscript) I'll take a look.
Regards,
Thomas
On 21 April 2016 at 15:13, Worth Lutz <wal3 at mindspring.com> wrote:
> Hi All,
> I'm seeing a crash, "Aborted (core dumped)" at the end of a cli run of
> mapscript creating some PDF maps.
> I believe this same error happens when calling the same code through the
> web server.  That error is shown in the attached screenshot from the
> server.
> My php script has completed it's work and the error occurs during the exit
> of the program.  I think during cleanup.
> Google found me these two links which I think describe the same problem in
> Mapnik.
> https://github.com/mapnik/mapnik/issues/3323
> https://github.com/mapnik/mapnik/issues/3304
> I have determined that the problem is related to drawing a layer which is
> putting on labels.  I removed the Hwy symbols and just left the text and
> still see the problem.  Remove the text and the problem goes away.
> I'm running mapServer v6.4.2 on Ubuntu 14.04.
> Is this a known problem?  Or do I need to submit a ticket?
> Thanks,
> *Worth Lutz*
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160421/30196b4f/attachment.html>
