[mapserver-dev] Documentation process: workflow for simple edits
Even Rouault even.rouault at spatialys.com
Wed Feb 17 12:02:12 PST 2016
Following Jukka's remark about the barrier for entrance for doc improvements,
I've added a "Workflow for simple edits" section for a pure online github-based
workflow that should hopefully make the barrier lower :
http://mapserver.org/development/documentation.html#workflow-for-simple-edits
If it has errors or need improvements, use the above mentionned process to fix
them ;-)
Even
http://www.spatialys.com
