[mapserver-dev] FW: [mapserver/mapserver] Default Map Size too small (#5349)
Daniel Morissette dmorissette at mapgears.com
Fri Nov 18 09:15:23 PST 2016
+1 (as I wrote in the ticket already)
Daniel
On 2016-11-18 1:03 AM, Rahkonen Jukka (MML) wrote:
> Same here, we seem to have MAXSIZE at 5000 for high resolution printing.
> 4096 would be a better default. If people in 2003 were gathering data
> from WMS with large requests now they are collecting tiles.
> -Jukka Rahkonen-
> *Lähettäjä:*mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org]
> *Puolesta *Lime, Steve D (MNIT)
> *Lähetetty:* 18. marraskuuta 2016 1:39
> *Vastaanottaja:* mapserver-dev at lists.osgeo.org
> *Aihe:* [mapserver-dev] FW: [mapserver/mapserver] Default Map Size too
> small (#5349)
> Any reason not to do this? The reason the setting exists is rather
> obvious. I checked many of my mapfiles and indeed I bump the value to
> 4096. Not for printing but for generating metatiles. I think that's a
> stronger argument... --Steve
> *From:*Seth G [notifications at github.com]
> *Sent:* Wednesday, November 16, 2016 2:47 AM
> *To:* mapserver/mapserver
> *Subject:* [mapserver/mapserver] Default Map Size too small (#5349)
> Currently the maximum image size default is set to 2048 pixels. With
> increasingly large monitors and higher resolutions I keep hitting this
> limit when maximising browser windows, and getting an error message.
> It is confusing to new users, and requires having to always add a
> |MAXSIZE 4096|line to each new map file.
> I'd propose increasing the default to 4096. Users concerned about
> increased stress on their servers are more likely to know how to change
> this setting, than new users getting an error.
> I believe it should be a case of simply increasing the following?
> |#define MS_MAXIMAGESIZE_DEFAULT 2048|
> https://github.com/mapserver/mapserver/blob/66309eebb7ba0dc70469efeb40f865a8e88fafbd/mapserver.h#L262
> It was last updated in 2003 - so hopefully most hardware has been
> updated since then..
>> You are receiving this because you are subscribed to this thread.
> Reply to this email directly, view it on GitHub
> <https://github.com/mapserver/mapserver/issues/5349>, or mute the thread
> <https://github.com/notifications/unsubscribe-auth/ABhm-_L5ZzWv-CqcKR5rT6mCKOU3UB0Rks5q-sMIgaJpZM4KzjdV>.
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
T: +1 418-696-5056 #201
http://evouala.com/ - Location Intelligence Made Easy
