[mapserver-dev] https url with MapServer as WMS client
Bas Couwenberg sebastic at xs4all.nl
Thu Aug 24 04:27:53 PDT 2017
On 2017-08-24 13:20, Yves Jacolin wrote:
> It seems that curl doesn't get the certificate to check the url and so
> failed. Do you have any idea how to manage this:
> * is there a parameter somewhere to defined?
> * do we need to install the remote certificate localy?
The certificate of the site is probably self-signed or not signed by a
CA that is included in the CA store on your server.
You can download the certificates into a bundle file and set the
CURL_CA_BUNDLE environment variable to use this file.
Kind Regards,
Bas
