[mapserver-dev] Skip failures when drawing a map
Stephen Woodbridge woodbri at swoodbridge.com
Tue Feb 21 12:40:37 PST 2017
On 2/21/2017 3:26 PM, Tamas Szekeres wrote:
> Hi Devs,
> Would that be a reasonable option to skip layers which are failing to
> draw and don't abort the entire drawing session?
> If yes, should that be a per-layer or per-map setting?
Tamas,
How is the layer failing? this is probably key to the problem.
For example we already have CONFIG ON_MISSING_DATA "IGNORE", what other
failures should we ignore?
Maybe:
CONFIG ON_CONNECTION_FAILURE "IGNORE"
CONFIG ON_BAD_DATA_FILE "IGNORE"
others?
Some of these may or may not be easy to recover from.
-Steve W
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
