[mapserver-dev] Skip failures when drawing a map
Daniel Morissette dmorissette at mapgears.com
Tue Feb 21 15:09:59 PST 2017
My 0.02$ is that whatever we do we should try to make it compatible with
the CONFIG ON_MISSING_DATA option that Steve mentioned. See RFC 47:
http://mapserver.org/development/rfc/ms-rfc-47.html
Daniel
On 2017-02-21 4:33 PM, Tamas Szekeres wrote:
> Steve,
> I'm not sure about a specific failure, this is upon user request.
> Probably they would just ignore everything that cause failures for that
> layer.
> Tamas
> 2017-02-21 21:40 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
>     On 2/21/2017 3:26 PM, Tamas Szekeres wrote:
>         Hi Devs,
>         Would that be a reasonable option to skip layers which are
>         failing to
>         draw and don't abort the entire drawing session?
>         If yes, should that be a per-layer or per-map setting?
>     Tamas,
>     How is the layer failing? this is probably key to the problem.
>     For example we already have CONFIG ON_MISSING_DATA "IGNORE", what
>     other failures should we ignore?
>     Maybe:
>     CONFIG ON_CONNECTION_FAILURE "IGNORE"
>     CONFIG ON_BAD_DATA_FILE "IGNORE"
>     others?
>     Some of these may or may not be easy to recover from.
>     -Steve W
>     This email has been checked for viruses by Avast antivirus software.
>     https://www.avast.com/antivirus <https://www.avast.com/antivirus>
>     _______________________________________________
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
Daniel Morissette
http://www.mapgears.com/
T: +1 418-696-5056 #201
http://evouala.com/ - Location Intelligence Made Easy
