[mapserver-dev] LABEL BUFFER behavior changes
Lime, Steve D (MNIT) steve.lime at state.mn.us
Mon Jul 17 17:40:35 PDT 2017
Since symbol scale is applied to the label size and corresponding symbols it seems reasonable to scale the buffer accordingly. The old computation seems insufficient too. Problem is that you can't control the min/max buffer size. That could lead to some odd behavior. Could use min/max labels sizes to constrain buffer values.
Did you happen to identify the commit that accompanied the change? There were some some broad label refactoring RFCs where this probably happened.
Steve
From: mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on behalf of Tamas Szekeres <szekerest at gmail.com>
Sent: Monday, July 17, 2017 4:17:52 PM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] LABEL BUFFER behavior changes
Hi Devs,
Was that intentional that the BUFFER paramerer for the label depends on SYMBOLSCALE in mapserver 7?
For mapserver 6.x the buffer has been calculated as follows (in mapdraw.c):
label_buffer = (labelPtr->buffer*image->resolutionfactor);
For mapserver 7.x we use this formula:
textSymbolPtr->label->buffer * textSymbolPtr->scalefactor
where textSymbolPtr->scalefactor is in fact the layer->scalefactor
According to the documentation the buffer should be interpreted in pixels so the 7.x behaviour is incorrect I think, where the buffer depends on the actual scale/zoom.
I'm not aware of an RFC which would explain this change.
Let me know if I missed anything in this regard.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170718/a7d4a179/attachment.html>
