[mapserver-dev] RFC 119 - Vector Tiles...
Even Rouault
even.rouault at spatialys.com
Fri Jul 21 14:05:57 PDT 2017
Hi Steve,
> Call for review please. I need to add the syntax changes for MapCache but
> that's about it. Associated pull requests are:
> - https://github.com/mapserver/mapserver/pull/5376
* "the implementation introduces a new dependency on protobuf/protobuf-c". Perhaps add
"optional" dependency to make things clearer.
* "WMS_SRS metadata (layer and server) should include epsg:3857 and epsg:900913" : From
what I see in the code, the implementation is CRS agnostic. Might be good to know for
people who would like to do non conventional uses of VT.
* Perhaps the RFC text could mention the EDGE_BUFFER (default value: 10) specific format
option so that it isn't forgotten for the documentation. Same thing for the EXTENT (default
value: 4096) format option.
* I see mapwfs.c is also impacted. Should probably be mentionned in the RFC text as well. So I
see that the extent is enlarged when the BBOX WFS parameter is specified (which makes
sense of course). From what I remember, when a more complex filter involves both an
attribute and BBOX filter, that doesn't go through that code path, so other changes might be
needed else where to also do BBOX extension. But anyway WFS and MVT are likely not
commonly used together, so such cases might be dealt later as enhancements if the need
arises.
* Mimetype. I see you use a generic "application/x-protobuf" but
https://github.com/mapbox/vector-tile-spec/tree/master/2.1 mandates "application/
vnd.mapbox-vector-tile"
* Do you plan to add new test cases in msautotest ?
* Final remark: great work from you and Thomas!
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170721/6ef37400/attachment-0001.html>
